Aeromotive stealth
Just got mine $240 from ebay, did free shipping cos I bought it without bidding on Ebay
340lph @ 40psi and 13.5V
I was gonna take some pics of the install but it looks similar in dimentions to a walbro. Chances are I wont be able to do it this weekend either
Edited by sucram
Yea but why would you run intank, increases the chance of something going wrong, as well as reduced capacity, and more effort ;)
Wut?
I've been running my 044 like that for years now, so has my mate and that single, in-tank 044 is supporting well over 500awhp.
IMO, the 044 in-tank with a stock-type sock filter setup is way better than the 040 with integral pickup, and the 044 flows more.
Edited by bubba
Aeromotive stealth
that looks like a good pump @ 340lph :)
have u fitted it as yet & are the dimensions similar to that of the oem gtr pump?
there are 3 versions of the 'stealth' so which is the right pump? would it be the 'centre inlet', 'offset inlet' or 'offset inlet/inline'
a few other q's:
1. stevo - the A1000 has serious flow (800lph @ 40psi), do u know if it fits in the tank of an r32?
2. pierburg pumps have also been recommended, do they flow as much as the aeromotive pumps as i cannot locate a website representing pierburg pumps?
3. the 'stealth' is rated @ 340lph on 40psi, what fuel pressure would the gtr run at high rpm/load? reason i ask, flow drops significantly @ 250lph on 75psi (as per attached flow chart) whereas the bosch 044 flows 200lph @ 5bar = 72.5psi
Marko, fuel pressure isn't rpm dependant, it boost dependant. Our systems are 3bar systems, if you're then running 2bar of boost then the fuel pressure will be 5bar at full boost :thumbsup:
ok.
so my calculations should be based on something closer to 5bar fuel pressure as im running 21psi
My calculations are based on 5bar moving forward & here are my options...
1. Bosch 044: 200lph @ 5bar (more info: http://www.bosch.com.au/content/language1/downloads/fuelpumps.pdf)
2. Pierburg E3L series (700228510): 330lph @ 5bar (more info http://www.compsystems.com.au/index.php?option=com_content&view=article&id=106:pierburgefp&catid=2:ecu&Itemid=14)
3. Aeromotive A1000: 700lph @ 5bar (more info: http://aeromotiveinc.com/products-page/fuel-pumps/11101-a1000-fuel-pump/)
4. Aeromotive Stealth: 250lph @ 5bar (more info: http://aeromotiveinc.com/products-page/fuel-pumps/11140-340-stealth-fuel-pump-center-inlet/)
My concern with the aeromotive A1000 is if i can make it fit in the oem fuel pump cradle as it looks massivein comparison to the other pumps, there no dimensions available...
Pierburg flows 66% more than my 044 which is awesome...will the pierburg support 450awkw?
what are peoples thoughts?
thanks in advance :)
The Pierburg is very long and thin, like two Walbro's end to end.
The A1000 is around 3.5 inches round and 6 inches long as I remember. It can be mounted intank apparently but it is single speed, there are similar pumps around with variable speed to stop the fuel heating so much. These require -8 fittings and hoses at least for their rated output apparently.
Best and cheapest option is twin Walbro's cost and price wise, may not be the most reliable though but thats what I went for.
Wut?
Designed as an external pump. Not saying it won't be fine, just saying it isn't what it was designed for :)
So? An 044 internal is fine, I use one and control it with Vipec. Stop posting crap.
The 044 doesn't have an open end like the 023 and 040....so you clamp a sock on the bottom of the pump and solve the problem.
how did u set up your twin walbro's? any pics?
The M35 pump is similar to the 350z, it sits under the rear seat. One Walbro and -6 line for each rail running ID1000's, non return valves before the reg should let me know if one pump fails so as not to run lean.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
