Yeppers, some oem pumps are well capable of doing the job. Many z32's making 500+hp on stock pumps, however they are getting old, so a new OEM pump is always recommended :)
That's pretty impressive Dean. Are u running a relay on the factory wiring?
Have u tested the pump to see how much more it has got and what it could potentially support in terms of kw?
It was a full factory setup, factory wiring, like it had never been opened.
I've got twin nismos now so I can't compare....
Why did u upgrade your pump? Making more power or for safety factor?
I think I've hit a wall as I cannot source submersible fuel hose with an ID to accommodate the fuel pump inlet which is 15mm. I tried pirtek, gates, speed flow, earls and purple pig.
Gates stock submersible hose in 2 sizes and these only run up to 9.5mm.
Does anyone have any ideas on the best way to mate my fuel sock to the fuel pump? Fuel pump is a push hose fitting and the fuel sock has a female push fitting with an ID of 24mm. The generic fuel hose does infact work in terms of size for ID and OD, however, the outer skin will disintegrate as it sits in the fuel tank.
If I have no other option, I may run speedflow -10 push hose as EFI Performance suggested this and apparently does not break down in fuel (even though speedflow stated to me that it is not rated for fuel submersion.
When I bought my car the previous owner said it had a bosch 044
Had it tuned running 340rwkw no fuel supple issues what so-ever, even went drags 3 times etc
Upgraded last month to a walbro e85 pump only to find it had a stock pump in the tank lol
Its amazing what flow these OEM pumps can support. I might test mine in a bucket and see how many litres it flows over 1 minute...what is the best way to test this though, direct to the battery?
Marko, just cut off some hose off a fire truck. She'll be right mate ;)
how about some seasoned bong hose? Loool
I want to do back2back flow testing with the OEM pump and pierburg. I reconnected the OEM pump but the trigger switches it off after 5 sec.. can I connect the pump to the battery direct as I want to measure flow into a bucket over a period of 1 minute so that I can calculate LPH.
Update time.
I decided to flow test my OEM pump direct from the battery and was very surprised by the results.
Over a period of 30seconds, it flowed 2.7ltrs which equates to 324LPH.
The pump even ran low and started blowing bubbles as I couldn't fill up the 2 ltr bottle it was sitting in quick enough.
Am I getting a higher voltage / power supply from the battery, rather than the fuel pump harness located in the boot? How can the pump flow at such a rate?
Off the return, that way the fpr will hold it at the correct pressure/restriction. It should be a reasonable indication of the flow as long as there are no other restrictions. Eg. Blocked fuel filter crimped line ect.
just wondering
are stock 34GTT pumps enough to use as lift pumps for a surge tanks with two 044s. This is for 350kw+ on e85
or would using the Deatschwerks 300lph as a lift and two 044s be overkill/enough?
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
