hey all ! i just want to put some spacers on my car to clear my brakes!
just wondering how long are the wheel studs on the r32 gts-t? and how thick of the spacer should i buy ? i was thinking of getting spacers from Just Jap prob 20mm to 25mm.
what you guys think? i need some advice!
thank you all!
https://www.sau.com.au/forums/topic/360833-wanting-to-put-spacers-on-my-car/
  • 2 months later...
hey guys, sorry to hijack but I didnt want to start a new topic.
Basically I want to get 25mm spacers for my GTT. A lot of people are recommending the H&R ones? I'm wondering why this is? Anyway, I can get the H&R ones sent from the US (http://www.optionimports.com/itemdesc.asp?ic=HR5065662) for $220 or buy the Just Jap ones (http://www.justjap.com/store/product.php?productid=17024&cat=269&page=1) locally for $140. Any thoughts or comments?
The problem with the hub centric ones is if you go any smaller then around 25mm you have to cut a little of your old studs, unless you wheels have cut outs or extra holes for you old studs to stick through.
s
Either way spacers are dodgy and illegal and cause to many probs, I had nothing but dramas on my 31 even with hub centric spacers.
Its essential to have the correct hub size or use adapter rings. In NZ the max thickness allowed is now 20mm - you may want to check if there are any state rules about spacers. I can't imagine why they should cost over $200 unless they are made of titanium.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
