i hammered in the rear restrictor about 20mm then filled it to the top of the block with that liquid metal stuff you mix together with your fingers.
1.5 restrictor at the front and i brazed up the vct feed and drilled it to 1.5mm
n1 pump. I had problems on the dyno with oil blowing out the rocker breathers and i figured i had a bit of blowby and the oil could not drain back so i just pulled out the dipstick and have had no problems!
  • 1 month later...
Please don't use the standard restrictors.
I've had 3 sets of restrictors in mine. - R32 RB25DE Head.
  1. Standard (over 5500rpm = filled catch can)
  2. blocked rear with a 1.5mm front (not enough oil on start up)
  3. and finally 2 x 1.3mm which is perfect.
RB25det - blocked rear and a 1.5mm is apparently ok. Others may be able to share their cold start storys with the same setup.
The blocked rear and 1.5mm up front was fine once warm but cold starts I could hear something knocking about up top rear on the exhaust side - coincidentally that's the furthest away from the front 1.5mm restrictor.
With the 2 x 1.3mm all noises disappeared and all sounds sweet again. Also - no catch can filling either.
  • 4 weeks later...
hey guys i have a question, i have rb30et bottom end with s1 r33 rb25 head, thinking of running the stock rb30et oil pump
and most of the time i will be using it on the track. what oil restrictors would i need to use/get if any at all?
sorry for the n00bness :worship:
+1 for using two 1.3mm restrictors.
Just using one 1.5mm might be ok for a solid lifter setup.
my setup with 2x 1.5mm was still pumping way too much oil to the head as soon as you took it past 6000. its just been changed to 1x 1.5mm and 1x 1mm with a couple extra oil drains directly to the sump for good measure.
will see how it goes this time round.
1x 1.5mm is not enough for the hydraulic lifters (for solids sure that will work), 2x 1mm can be hit and miss, works for some gives lots of lifter noise for others.
when i brought my oil restrictors i just brought 2 blanks, one of which im drilling out to 1.5mm. iv already put the blank in ontop of the rear oil restrictor and its nice tight fit
I'm getting a adjustable feed for my 25/30 oil control problem, it is externally adjustable and will be set so when at high rpm the oil will be high enough for cooling and lubrication but will not overflow, by rights this should still see enough oil at low rpm to feed my lifters.
With my 2 head drains and the drain from the can to the sump hopefully the oil is going to stay in the motor.
Hopefully.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
