Get a replacement or better after market fuel filter
Locate fuel filter (I don't have an R32, but I think it is in the back under the trunk?)
Unplug fuel pump fuse
Start car, let die :O
Try to start car again to be sure there is no left over pressure in fuel line
Pull out old fuel filter
Enjoy getting high from fuel
Put in new fuel filter
Return fuel pump fuse
Start car, let idle :cool:
Done
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-5762879
  • 8 months later...
Sorry to dig up this old thread but didn't think it worthwhile starting a new one with the same topic.
Would someone be able to tell what size fuel hose to buy, I'm about to change my filter and want some spare fuel line on hand in case the original stuff is damaged when I remove the old one, probaly a good idea to have a couple of new clamps too.
Regards
Mike.
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-6159070
Got the filter from Nissan Coopers Plains for $33 though they tried to charge me $39 apparently the price changes from when you ring for availability to when drive there to get it.
Also the Repco man tried to talk me into $28 per meter high pressure line, though I walked out with the standard 5/16th, stuff for $6.
Mike.
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-6160903
but you do need the high pressure EFI fuel line dont you???
I know thats what I use...
To be honest I don't know, but the line I had to cut off looked to be original and of the same spec as the cheaper line I bought. Would be good if someone in the know can confirm.
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-6161220
Id get EFI line. Peace of mind is better then saving a few dollars
Very true, I did a little research on the line I bought and it seems to have a working pressure of 50 psi, might try and source some 150 psi stuff. I don't want to start any fires in my engine bay, or anywhere else for that matter.
Mike.
Edited by Missileman
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-6161277
That line you got is used mainly for carby engines, it can blow out/split if used on EFI applications. Also, you can use a z200 fuel filter, its alot cheaper than the one earlier posts have gotten
https://www.sau.com.au/forums/topic/360983-fuel-filter/#findComment-6161321
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
