I'm currently running the same SARD 700's you are while making 400awkw at 21psi. My duty cycle is sitting on 79% but that power had been made with quite a bit of mechanical tuning as well. Happy to give a full list of specs if you need. I'm running normal 98 RON so you shouldn't have to change unless you really want to go to E85 in the near future.
what percentage is considered dangerous, i.e anything over 90%? when do injectors lose efficiency?
The only problem with running injectors at 100% is that you are not controlling the fuel.
The injectors will happily sit at 100% all day. So will injector drivers in ECU's
But if you are at 100% then you are at the limits of the elements with fuel control. If a condition changes, eg. 1 more psi, colder charge temp etc, there is no adjustment for this.
This is the only reason that 100% DC is not recommended.
i used to run 1650cc on my pfc
Sorry to bug you Marko but, can I have some details, I was told that the max you can run was 1000cc or atleast with any sort of resolution ?
Im running ID 2000's and they are fine.....
Im using 700's. Based on the scaling of my MAP sensor and running 1.6 bar with a rich 11.5:1 afr I think there is room for well over 400kw from the 700's, provided you can make that power below 8500 rpm. My calculations show that at 1.7 bar boost and at around 8000 RPM i'll be brushing up against the 100% duty limit.
My hope is that i'll achieve 450kw at the tyres with this setup, and at the most with the addition of water/methanol injection. Im using a nismo in tank pump too.
Edited by GTRNUR
Well my plan is stay on pump 98 so I'm hoping I can get away with 700's.
I'm also going to run a pierburg fuel pump intank which supports 360lph, compared to the 044 which runs 200lph it is 66% more efficient.
I'm going for a clean setup :)
Not many ppl know about the pierburg apart from the odd workshop. They run them in the mercedes amg series and the bugatti veyron
Course you'll get away with them.
700cc - ~700hp, that's @ factory pressures too.
I don't even see 70% duty with 370rwkw from my 700 Sards. About 65% i think is the most.
ok - i'll let crd decide when i take it to jim
Nice well Im just going to dump some ID 1600's into my HKS rail and see how she rolls.
I was always told by a certain person that a PFC will not run over 1050CC injectors...
Awesome, thanks guys.
The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
