  • Replies 93
Posted Images
Good to see everyone. See those at Winton next weekend then DECA and WRX Sandown after that.
The supra was sporting a sequential gearbox and was seriously moving, also a V8 supercar (spec'd) that got pinged for noise after 2 laps.
We kept it on the black stuff, but one of the GM boys didn't and the armco at turn 3-4 were rearrange a little.
Was good to be back out there, even if after my first exploratory session I was pinged for noise. So didnt even get to put a lap in :( I did go out in the wet in the afternoon but was forced to shift at 3,400rpm due to noise :( But got to put som eheat cycles into the new brakes
Oh well. I had no idea where the correct braking points were and was just trying to bed the brakes. So much harder to pick the braking points compared to Winton. Once they were up to temp I put in two laps to really jump hard on the brakes to get them nice and hot then backed off to let everything cool down.
Was shocked that I did a 1:25 flat. The old girl seems to drive about the same despite the dyno showing I have lost a fair wack of mid range. I reckon if i didnt get pinged for noise it would have been fun chasing the Supra :)
In all it was a trying day, picked up a puncture from a screw in the carpark, Radcam farked up again and didnt get a 90% tilt at a lap....but I think the brakes passed their test and I got some seat time which is drastically needed.
Well done Bris, looks like the old girl has still got it in her. Mate I'd love to see what this thing would do with a decent wheel alignment, quiter exhaust (to be able to go flat out) and more seat time.
Third fastest overall, gotta be happy with that.
Look forward to see how you go next Sunday at Winton...
Apparently the Supra is currently a couple of hundred HP down on what it used to be, I have seen it about the traps a few times and thought at a sprint earlier this year that it was not as quick as I remembered. Still no slouch!
I was happy enough with a 1.31 in my coupe given it is effectively the first time I have run it there (Got about ten laps the only other time, stuck behind some nong in a Gemini who was like a snail through the corners and dead set fast in a straight line, and then it rained so hard that they stopped the day) I could certainly have gone a few seconds quicker with a bit more bravery under brakes at the end of the two straights.
I can say that a HR31 on semis is not a lot of fun without power steering, the belt failed in the first wet session so it was armstrong time! It was still managable (Just) so we kept running. But with the rain it made hard work of a twitchy car, 200 odd RWKW at 5600 rpm and seriously snappy onto boost in the rain is sort of attention focussing. Second was virtually unusable, third was inclined to break away at about 4500 rpm and it broke away a couple of times in fouth. Would have been great fun with the PS pump still doing it's thing.
Yep, that would be the one, it used to be an absolute rocket in a straight line, now it is just very very fast. I was told yesterday that it is nearly 200KW down on what it used to have! I have been told in the past that it had around 500KW and given the straight line stomp it had first time I saw it, I would think that was possible!
Interesting way they unload it. It arrives on the back of a flatbed rigid truck parked on top of a steel lifting frame. They hook the truck mounted crane to the frame, hoist the whole lot on to the ground next to the truck and then push the car off on the flat. It would be nice to have money to have toys like that.
Guest
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
