Just completed a re-build:
JE 87mm pistons
Tomei OGK - 1.2mm
ARP Head studs
Cosworth Bearings - Std
Tomei Poncams - 260/260
Apexi PFC - D Jetro
Koyo 4 core Radiator
N1 oil pump
Mishimoto 62c Thermostat
GT2860-5 Turbos
Mines Titanium DP
3.5" SS Jasma Exhaust
Car runs well and maintains water temp in the 70s and oil temp in the 80s when driving.
Problem is when idling for more than 10mins, water temp rises to 90c+. If the car is parked soon after, about 200ml of coolant flows out of the expansion tank.
Advice?
https://www.sau.com.au/forums/topic/361704-rb26-rising-temp-advice/
you might have a basic water pump issue or some sort of flow issue
90 isnt that bad, but it shouldnt move past 90
ask the engine builder?
the n1 water pump flows less at idle vs stock as its designed for high end RPM high flow
so at idle, it will actually be outperformed by the std water pump in terms of flow
when did this start? since the radiator change?
check the basics etc
Would an N1 water pump help?
not really.
You've gone a put a part in thats not fit for the application - a 4-core rad.
As you've stated it's perfectly fine when driving, and it will be... Or more importantly track - which is what i'll guess it's designed for. Not street.
I could be wrong, but all bets point to the rad as the issue.
You might have not bled it correctly or something and have air lock/bubbles. But i doubt it.
I built the engine myself and it definitely goes past 90, but if I keep the revs up above 2k, it drops slightly.
The problem started after the re-build which is the same time I installed the new rad.
Already bled the system twice. No change.
Is it a 53 mm koyo radiator? If it is I have the same on my r33 gtr
I have never had a problem like this, normal driving temp is at 66 deg n when at idle in traffic it may only move 1 or 2 degrees
Thermostat only determines when the water starts circulating. Once it is open it has no effect on max temps (only minumum temps in a very cold climate). Stock would be better as 70deg is not hot enough. Have you got a shroud for your fan? Fan doesn't do much without one.
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
