Just completed a re-build:
JE 87mm pistons
Tomei OGK - 1.2mm
ARP Head studs
Cosworth Bearings - Std
Tomei Poncams - 260/260
Apexi PFC - D Jetro
Koyo 4 core Radiator
N1 oil pump
Mishimoto 62c Thermostat
GT2860-5 Turbos
Mines Titanium DP
3.5" SS Jasma Exhaust
Car runs well and maintains water temp in the 70s and oil temp in the 80s when driving.
Problem is when idling for more than 10mins, water temp rises to 90c+. If the car is parked soon after, about 200ml of coolant flows out of the expansion tank.
Advice?
https://www.sau.com.au/forums/topic/361704-rb26-rising-temp-advice/
you might have a basic water pump issue or some sort of flow issue
90 isnt that bad, but it shouldnt move past 90
ask the engine builder?
the n1 water pump flows less at idle vs stock as its designed for high end RPM high flow
so at idle, it will actually be outperformed by the std water pump in terms of flow
when did this start? since the radiator change?
check the basics etc
Would an N1 water pump help?
not really.
You've gone a put a part in thats not fit for the application - a 4-core rad.
As you've stated it's perfectly fine when driving, and it will be... Or more importantly track - which is what i'll guess it's designed for. Not street.
I could be wrong, but all bets point to the rad as the issue.
You might have not bled it correctly or something and have air lock/bubbles. But i doubt it.
I built the engine myself and it definitely goes past 90, but if I keep the revs up above 2k, it drops slightly.
The problem started after the re-build which is the same time I installed the new rad.
Already bled the system twice. No change.
Is it a 53 mm koyo radiator? If it is I have the same on my r33 gtr
I have never had a problem like this, normal driving temp is at 66 deg n when at idle in traffic it may only move 1 or 2 degrees
Thermostat only determines when the water starts circulating. Once it is open it has no effect on max temps (only minumum temps in a very cold climate). Stock would be better as 70deg is not hot enough. Have you got a shroud for your fan? Fan doesn't do much without one.
  • 4 weeks later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
