hi.i have r33gts fitted with the rb20e.i would like to knw can i run the rb30e on the rb20e ecu with a piggyback to sort out the fuelling and ignition.just want abit of more power for now to move the heavy body.will the rb30 bolt straight in using the stock rb20 engine mounts.
https://www.sau.com.au/forums/topic/361822-rb20e-to-rb30e-in-a-r33gts/
forgot to mention im from south africa.want to do a rb25/30 at a latre stage.whats the difference between a r33 rb25de and arb25de neo.from what i've read the neo got smaller combustion chambers then the r33 rb25de so the comp should be high enough if you use the rb25 neo pistons
was thinking of doing that.how hard is it to fit a vh45 in a r33.i've read john's thread bt it dnt say if he had to mod a few things to fit it n most info u get is how to fit it into 300 zx n s13/14s n not much into skylines
It would be a pretty similar affair. Should be easier than a Silvia I would think as the bay would be bigger to start with.
should be an awesome car seeing what john done with his one but back to topic can my rb20e ecu run a rb30e.i'll be using everything on the rb20,inlet manifold,injectors,dissy and the exhaust manifold.i think it would run fine.im mostly after the extra touque of the rb30 till i upgrade later.
i think it should cz the rb30 in south african r31s ran with 21 deg timing.dnt knw if the injectors are the same size.it mite pick up a few extra kw cz the r33 rb20 inlet manifold seem to have bigger runners then the rb 30
Ive got an rb30e in my r33 and it smashes the pants off rb25de`s
the torque is good. Not so great on fuel tho
Engine mounts will be the same as the difference is in the block height
in terms of managment its best to use an rb30e loom and re wire it to suit the r33
Ebay has some cheap turbo kita for rb30e`s if u wanted more power later on
if u are serious pm me and ill send u some pics of my conversion and the wiring
contact nistune in australia who will be able to "chip" your rb20e ecu to run different fuel and timing maps to suit the rb30e.
my rb30 is n.a
basic mods: GTS style extractors 6-2-1, 2.5inch cat back zorst, pod filter, advanced ignition timing running premium fuel.
car has a 4.46:1 LSD, that helps ^.^ i dragged off a WRX to 100 km/h the other night
the car realistically has around 100 rwkw, with a cheap turbo kit it would have close to 170 rwkw
nice.im from south africa so my best bet will be to get a dastek piggyback ecu.currently got a pod n 57mm straight through exhaust with a rear can box.im making 85kw on da wheels.my best 1/4 mile is a 17.5 lol.with 100 on da wheels n more torque i mite get in the 16s
skit it will be hard for me to get the parts.i will be upgrading to a rb30det at a later stage just want sum extra power to move the heavy body.chris how high do u revyour rb30.seeing as the rb20e has a higher rev limiter i'll to let the piggyback ecu limit it to 6100rpm
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
