I started this build 3 yrs ago after burning a valve, and as you do you crack the engine and see what you don't expect.
After stripping the engine down I found out beside a new valve, I also needed a new crank which had a nice hair line crack thru an oil journal.
I installed a new R33 crank which was slightly modified, trust pistons & rods with ACL bearings. I had the compression, deck hieight, & squish modified.
I also installed stainless 1mm over sized IN & EX valves. I retained the cams that were already in the engine which where old school " TOMEI 260's " which I found engraved in the shafts. I believe that's what they did before they made PON & PRO versions.
I decided to do an external oil pump setup which I did myself. I used a moroso single stage oil pump and contracted an awesome fabricator called Billet Motorsport in Vic to make me brackets and front pully out of billet aluminum. The front crank drive pulley is a one piece item to reduce possible component failure and the brack system was all NC'ed with billet spacers and bolts. I had it done to match the Ati balancer I chose to install.
Next step was to modify a RB30 oil pump by removing it's gears & topping off it's oil feed gallery so I could connect braided feed lines to the external oil pump.
I contracted Brad at Westside Mufflers to make a custom 9ltr sump extension with windage gates, custom pickups & drain. Once the sump was completed I contracted Westend Performance Engines to machine, build & assemble the engine.
With the engine completed and dropped into the bay I continued with the oil pump system. I got Steve from Earls to come take a look and get his advise on the best fittings and lines to use. After making all the Earls lines and fittings the installation was simple.
Getting close to starting the engine I started thinking about what fuel I wanted to run and after 2 sec of thought I decided with E85. I consulted Adam at Just Engine Management, he advised me that I would need approx 30% more fuel capacity so I decided to ditch my 700cc injectors and get Xspurt Bosch 1600's.
At this stage my GTR was still running the Haltech E11v2, seeing the capabilities of the new Platinum Pro plugin ecu I decided to sell the E11 and upgrade.
It was very tempting to sell the T88 setup and get a more modern design turbo but I knew it would perform since I had already install a 6boost split pulse manifold which made a massive difference on the previous engine.
So eventually Adam at JEM loaded it onto his dyno for the run in. After running it in on the dyno for a while it ended up with 405kw on gate pressure 1bar spring which I was very happy with.
I put the km on it, installed 2x -6 Teflon braided lines from each fuel pump to each side of my fuel rail to give it the best chance of supporting the power I was hoping for.
After 6 mths went by Adam loaded it up again on the 4WD dyno. 2nd dyno run it was already at 488kw, 3rd run 512kw, 4th run in it made an amazing 525kw at 4 wheels on 25psi and has 22psi of boost at 4,700rpm. during that run we could see the 2 Walbro pumps were getting to their limits so I decided that was enough for now until I upgrade them.
I'll upload all my pics & vids of the build next.
Hope you like it
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/
My damaged valve
The front wheel measures 102mm outer diameter
post-1009-0-97279600-1303627349_thumb.jpgpost-1009-0-24613000-1303627396_thumb.jpgpost-1009-0-88270500-1303627251_thumb.jpg
The Billet Motorsport brackets and pulley setup
post-1009-0-64991700-1303627459_thumb.jpgpost-1009-0-59605400-1303627503_thumb.jpgpost-1009-0-70744300-1303627522_thumb.jpgpost-1009-0-79692900-1303627563_thumb.jpgpost-1009-0-13202300-1303627769_thumb.jpgpost-1009-0-39374200-1303627879_thumb.jpg
Custom sump extension done by Westside Mufflers
My custom head drain
My Xspurt Bosch 1600cc fuel injectors
Modifying my twin walbro fuel pump setup for E85
post-1009-0-19681800-1303628625_thumb.jpgpost-1009-0-83904200-1303628735_thumb.jpgpost-1009-0-04021600-1303628822_thumb.jpg
1st time start plus run-in tune
And power tune 525kw at 4's at 25 psi with the fuel pumps at their max.
Edited by mrchams
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5777012
Ahhh I remember this car from when it was in Zoom mag all the time, nice, good to see how have gone a long way power wise since then.
Wow, you've got a good memory, yep it sure was the HPI project gtr.
Since then I've not only built my GTR engine but had 3 kids alone the way... lol
Thats one of the reasons its taken so long.
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5777126
The 1mm oversize valves
My pistons
Picture of the bore that had the damaged valve
Inside my custom sump
Engine bay photos with new read paint
My Apexi valve springs
My triple plate clutch
6BOOST manifold and 50mm gate
Edited by mrchams
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5777137
Buy a real car mate Go the STI lol.
all i want to say is well done so happy that you have finished the build and you are happy with the outcome
Keep up the good work son
All I can say is we are going to have fun you trying to catch me in your 34....lol
So how did it go on the freeway on Thursday night?
Next time I'll need to remember to mount the video camera and film it....
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5777150
I couldn't believe how well it went on 14psi, it was strong!! Definitely the most responsive T88-34D setup I've ever driven, I could imagine that extra power would be nuts. Time to drop a pair of 044's in that surge tank Deano :)
That engine is mega efficient :) We'll be cruising soon!
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5778583
I can't wait mate. I think the last cruise was that awesome south coast trip, we should do that again.
Kyp got his 32 back and is running it in too. everyone's is getting back on the road!
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5779267
  • 1 month later...
hey dean, good to see you the other day at JEM when I came to catch up with bobby. is the engine back together yet?
how do you like the sard surge tank with pumps mounted inside? I'm about to do the same set-up on one of my 32s as i quite like the idea of mounting the pumps inside the surge tank (fuel is good at insulating the noise a bit and also keeps the pumps cool).
https://www.sau.com.au/forums/topic/361824-r32-gtr-t88-34d/#findComment-5866970
  • 3 weeks later...
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
