hey guys i dont use my modified stagea much these days and looking to purchase a house so im thinking of selling it but unsure what it is worth and if anyone would be interested in such a setup, or maybe its better to strip it back to stock and sell all the parts off?
im not too fussed if i sell or not, i have had the car since 2004 (and been on theses stagea forums since then), it has undergone alot of changes in that time, and recently featured in Performance Imports magazine with the old setup it had. It is no where near as modified as it was in the magazine as i got a defect notice and decided to make it completely legal and put the modified engine into a track only gtr instead.
The mod list is pretty long but here is the basics to give you an idea...
rb30 bottom end, freshly rebuilt with new pistons (not forged but stronger than stock, they are called Endurotec and made by Precision), its got a crank collar on the crank, all assembly was washed, machined and balanced. Has done about 2000km so far. It has a gtr oil pump on it, brand new water pump, new tensioner and idler pulleys, new timing belt and all new seals, and hks drag metal head gasket 1.2mm.
rb26 head is also recond and in as new condition with all standard rb26 gear.
The block also has a "Pro Engines" 4wd sump adaptor kit fitted to allow for the gtr 4wd sump to be used.
this is a copy and pasted list of the mods i can remember...
stagea rs four s1 silver
mods:
rb30 rebuilt bottom end
king bearings
endurotec 86.5mm pistons
hastings rings
Proengines 4wd sump adaptor
gtr 4wd sump setup
rb26 head & plenum setup
freshened up with new valve stem seals, redone valves, shims setup, deck etc
hks drag 1.2mm metal head gasket
hks drag metal intake and exhuast gaskets
gt3076r turbo
custom steam pipe manifold
hks 50mm wastegate
3' dump pipe and exhuast with magnaflow muffler and an apexi centre muffler
K&N pod filter
custom alloy cooler piping and intake pipe
custom metal oil and water lines
gtr 5 speed manual box
extreme single plate clutch
32 gtr diff and axles
33 gtr brembo rear brakes
34 gtr brembo front brakes
dba 5000 alloy hat front slotted rotors
dba 4000 rear slotted rotors
custom adr approved braided brake lines
r33 handbrake
4.11 front and rear diff ratios
autronic smc ecu
eboost 2
defi 3 din gauge setup
whiteline springs all round
bilstein shocks all round
all noluthane bushes throughout front and rear
arc front swaybar
whiteline rear swaybar
adjustable camber bushes
nismo lmgt2 rims 18x10
dayz rear bumper lip
nismo copy sideskirts
thats about it i think lol.
i have invested alot of money into the car over the years and only used top quality parts throughout.
heres a couple of pics of the motor and car itself
i have full engineer reports for all mods and engine conversion/brakes/etc, the only mod not approved is the single turbo, i can put stock rb26 twins back on it and take abit of money off the price and then its fully legal. The engine block is stamped as an rb26 so no worries as no one can tell its a rb30 at all, passed the inspections with no dramas.
this is a pic with stock turbos on it and looks completely standard to the untrained eye. You can put some upgraded low mounts on it and make heaps of power without any issues with police etc.
The current setup is only roadtuned but making around 350hp at wheels, and cam timing hasnt been touched yet so has alot more in it, and should make low 400s without any dramas or reliability issues at all.
so what would you guys think it is worth?
As sad as it is, the money you have put in. Is going to be many times what younwd get for it, it looks maybe too far to go back to stock, As finding an engine etc wd out weigh wat an s1 is worth. Let alone the scare factor when you tell people its not factory engine etc. The motor alone wd fetch ~10k dont we think? Other than that ur breaks, handelind mods n gbox wd get u a bit more. Strip it n move on..?
yeah likewise, i would have bought it pretty dam fast a few months ago, but if you strip it, let me know how much the brakes are, hawttttt
btw, dont strip it or sell it, just hold onto it and use it when you can
What's it worth? A lot more than you could ever sell it for.
Plan A - just keep it (what are you towing your track car with?)!
Plan B - stick a price on it that you would be happy with and wait for someone to come on this forum looking for a good C34 and buy it.
Plan C - if you must sell it wait until you can organise an engine swap with someone - I would have paid someone $10k and given them my old engine for one like yours - (and as many other bits as they can afford) and then sell it.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
