Hey guys im new to SAU,ive been looking/googleing for some information about oil coolers but still not enough out infor,SO at what power is the oil cooler required?i guess it all depends on what application its uesed for track/drag/street.
and how much xtra oil is needed if a oil cooler is installed?
if a oil cooler is installed will it take longer for the engine to warm up is it bad?Does it need xtra time to warm up?
Im more aiming at street an 1-2 track days a year running 400kw.
Is a oil cooler needed for a 400kw gtr street driver..
Might get the odd street drag every now and again :D
cheers
Edited by nitestage32
https://www.sau.com.au/forums/topic/362053-when-is-a-oil-cooler-needed/
wouldnt need one for the street.. and if you do fit one and street it, get a proper thermostatically controlled one.
+1
If you are even doing one track day/yr, oil cooler is paramount however.
How much extra oil depends on all the other factors like cooler size, mounting, lines etc. Only way is to do.
Track + 400kw means you will need one if you want to be out there for any length of time. Street and drag are ok without it. Some kits go in front of the radiator (eg the HKS kit i'm using) which is less effective. With that much power you'll want to have it in front of the front wheel using the openings under the headlight to get a good flow of cool air through the core.
Not that much extra oil, maybe a litre?
Doubt you could find better for the money.
http://www.skylinesaustralia.com/forums/topic/357901-hel-thermostatic-oil-cooler-kit-group-buy/
And as others have said. Thermostat is a must for street use. And at 400kw I wouldn't even go out on the track without an oil cooler, especially if you live in a hot climate area.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
