This is not a rant thread, or a thread made of anger. I seek logic and a proper answer.
I had just had a set of yellow jackets fitted into my car. They came in after a new clutch was fitted in so as you may have guessed, yes I have been driving like an old lady with many low down shifts and slow accelerations to bed the clutch in.
Both have been in the car for a week, maybe two tops. Today my car turned into a WRX. The sound of a cylinder not firing immediately caught my attention. After about 5 mins of diagnosis, I pin pointed it down to cylinder 2 and not the cylinder or spark plug but the coil pack. Fitting in my old coil remedied the problem and now Ive sent my request for replacement or a solution.
I'm now wondering as to what could cause such premature failure. Heat? Bad build? Something else? Ive run my coils without the coil cover to let out the excess heat. I have a standard bonnet(no vents) so no water or foreign material could get into it. Physical inspection the coil looks healthy.
Any ideas as to the cause? Could there somehow be insufficient grounding contact? Can I test this with a multimeter and check resistance or something to see if there is break inside the unit?
Edited by SargeRX8
https://www.sau.com.au/forums/topic/362147-why-did-my-yellow-jacket-coil-fail/
yeah i'd say it was just unlucky that you got a faulty one. if you bought these off performance-wise, i have no doubt he will sort you out asap.
ive been running yellow jackets for ages now, with no hint of trouble.
i'd say it failed because it's a yellowjacket ;)
seriously though, have you checked your plugs? driving around like a granny where your tune is super rich can foul them pretty badly...
There is nothing wrong with yellow jackets.
They work as well as split fires and brand new nissan coils.
In fact, my Yellow Jackets withstood more abuse then my split fires did before one melted...
Also, it won't be the plugs if he's swapped the coil packs and it has fixed said issue... ;)
I don't know if this is related but I have just noticed it a couple days ago. Since fitting in the new clutch I literally did not rev the car past 3 - 4krpm for the last 200km of driving. Today I went to give it a little in first gear(after about 40 mins of driving) and the car revved fine to about 2500 then it like, I don't know how to explain it but it felt like the car choked for a half second then drove fine to red line through to second. Its like when you cough something up. Its smooth coughing then the shit comes out and there is a slight turbulence. I don't know if its because I haven't driven the car hard or something related to the coils. Driving at 60km/h and putting it down into second is fine. It only does it on first gear. I don't know if it will do it again in the same drive but I don't push it again if it does that. I thought it may have been the oil but I doub't it, sougi s6000. It didn't really start this until I drove the car like a bitch and installed the coil packs. I'm gonna start gaining weight on my foot again to see if it keeps happening.
My old car used to do it only when cold.
  • 2 years later...
Guess it's a common issue, I've just had another one fail.
Might see if performance wise can do anything about it as it's out of warranty. I've already replaced one with a brand new one. However looks a little different in terms of build quality. Maybe shit batch :(
i've had a single YJ "fail" as well - it wasn't a total failure but after 2 weeks it started breaking up on boost. performance-wise swapped it for me immediately, great service.
considering they're half the price of any other option on the market... it's still a win - even if you are unlucky you know it will get sorted out ASAP.
A bit of an update, I ended up getting a replacement coil for a pretty good price, considering my set was out of warranty (came with the car & no receipts).
Dealt with Paul from Performance-Wise, good bloke and was pretty understanding and said if others from that batch fail he will still honour that discount he provided.
Now that's customer service! :yes:
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
