The last 18 months I've been living in Thailand, so I've decided to sell my GT-R as I and will be returning there soon.
Here are the specs:
1992 NISMO Edition R32 GTR 84,000 km’s
Car has done only 11,000km’s in 7 years of ownership
$20,000 spent on upgrades and mods
Serviced and tuned by RacePace Motor Sport
ENGINE:
Nismo Steel wheel turbos
Greddy Adjustable Cam Gears
Twin Apexi Pod Filters
Tuned by Ben at RacePace at 235KW at the wheels
DRIVE TRAIN/CLUTCH:
Exedy full-face single plate carbon clutch
VSpec 2 Brembo brake calipers with Lockheed rotors front and rear
KSP exhaust system
SUSPENSION/BRACING/WHEELS:
Buddy Club Rims
Front and rear strut braces
Tein coilovers
INTERIOR/EXTERIOR
Nismo side skirts, front bar ducts and rear lip spoiler
Nismo 260 km/h speedometer
Apexi turbo timer
Razo accelerator, brake and clutch pedal set
Razo gearstick
Original GT-R floor mats
Leather handbrake and gear stick boots
Original Nissan GTR front & rear seats in excellent condition
Alpine head unit
Alpine 6-stacker CD player
Alpine V12 amp
Orion CS200.4 amp
Kenwood front speakers
HZ rear speakers
Immobiliser / Alarm
Price: $24,950
I'm located in Melbourne. Mobile: 0412 101 571
You can also PM me if you're interested.
Cheers
Ben
Edited by ben3232
https://www.sau.com.au/forums/topic/362279-r32-gtr-1992-nismo-edition-for-sale/
if so it is a 1 in 560 Nismo Group A Evoloution cars ever produced
would make it kinda rare????? seeing there was about 43,000 R32 GTR's built
Edited by ML73ZR
According to the Chassis Plate decoding sheet I have.
K-Coupe
B-2.6L (GTR)
N-Super Hicas+Attessa
R32-R32
R-2 Doors
X-GTR (16 inch Wheels)
F-5 Speed Manual
S-Intercooler+Turbo+EGI
MA-?
For Nismo GroupA Limited Edition I have the code RA
Also according to this thread http://www.skylinesaustralia.com/forums/topic/341653-r32-gtr-nismo/ Nismo additions should have the build number BNR32-100XXX. XXX is the build number eg BNR32-100323
Check on page 2 where there is a Nissan fast picture and the code for it is RA.
Post up in the Fast thread your VIn number and see what the program says about the number but to me it looks like it's not a Nismo edition sad.gif
my GTR is exactly the same as this, its got the MA code in the vin numbe, they also have no rear window wiper and on the dash it has no switch for it either,
K-Coupe
B-2.6L (GTR)
R32-R32
R-2 Doors
F-5 Speed Manual
MA-?
Thanks Chris. I've posted the vin number in the fasted thread. When I get the results I'll post it in this thread.
Cheers.
according to this http://imports.motortraders.net/imports/select.asp?make=Nissan&model=Skyline it looks like the rear window wiper was a standard feature, i think its an optional feature on the r33s
K-Coupe
B-2.6L (GTR)
R32-R32
R-2 Doors
F-5 Speed Manual
MA-?
Chris, can you have a look at let me know your thoughts?
Edited by ben3232
Good news is that the FAST and your build plate line up. Does the number stamped on the firewall match up with your build plate? Bad news, to me the chassis and model don't line up with the NISMO edition. I could be wrong, but NISMO edition was built in 1990 and into the start of 1991. I have been thinking that MA could be for some factory options, for example L-Fog lights, P-Sun roof. So MA could stand for something.
Even if it's not an NISMO edition it's still looks like a tidy car.
Yep the number stamped on the firewall matches the build plate.
Cheers Chris, appreciate the help.
Edited by ben3232
Stunning car, and a good price!
re the NISMO plate, what you might find is that NISMO would attach these plates when fitting certain parts in their workshops. I've seen them done for NISMO clutches and based on the plate above RS590 refers to the NISMO rear link set (suspension parts).
No idea what MA is, but NISMO cars definitely had RA in the chassis code
Saw a thread previously (on the ipohne so hard to find) which said that MA may indicate a limited factory run or option (like Chris said), things like airbags etc. The nismo plate as mentioned relates to work done by Nismo and the number to what was done
  • 3 months later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
