Hi Guys and Gals,
For the upcoming Drag Combat event (April 10th) I'm planning on having some more t-shirts made for the event, similar to the ones we had for PAS. This time the t-shirts will be black, and will have the SAUWA logo, and Drag Combat logo's on them.
The cost will be approximately $20 again.
If your interested then let me know sizes, and send me some money, either directly of via Netbank. Be quick as we don't have long to sort this out. The t-shirts are very good, and I wear my PAS one all the time.
For the sizes, I wear a Medium, and people like Cam wear XL, so judge your sizes accordingly:D
Cheers
Paul
Kyles, XXS Paid
IMACUL8, XXL Paid
RB20LagWagon, S
Nizmo, S Paid
Sileighty, XL Paid
Memphis, L
Mikz, XL
Caminperth, XL Paid
Sneeza, M Paid
Shuto_boy, M Paid
13_Devil, S Paid
33Spec2, M Paid
PVA_Glue, M
Judged, XL Paid
Got Boost, XL, L Paid
GTS500, XXL
Drifta, L Paid
MrGTST, XL Paid
dan_the_man, L Paid
Neo, XL, XL Paid
Gradenko, XL Paid
Boostzor, XL
Micko, L Paid
Sub, L Paid
Wilz, L Paid
Skyzerr33, XL Paid
SeriesIIGTST, L Paid
Erik_tufa, L Paid
boost, L Paid
Vassil Paid
https://www.sau.com.au/forums/topic/36243-t-shirts-sauwa-drag-combat/
  • Replies 49
The easiset way to pay is via Netbank:
Bank:Commonwealth
Account Name: Paul R Cornes
BSB: 06 6163
Accnt No: 1000 6120
PS. Remember to include your forum name in the description.
paul, can i come around and pick it up from sst , as i cant net bank
-paul how big are u? i think small should be good size 4 me
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
