Ok Im not a fan of anything rice and spending $150 on a piece of sheet alloy with a $90 degree bend in it and a few holes wasnt my idea of fun. So after looking on google there were plenty of DIY out there for different cars. I got my inspiration from a few pics of them for the 34 GTR (can get them for your specific model of car if you wish) and to give me a general idea of the shape etc etc. My finished product is by no means perfect but for a fun cheap DIY im very happy with the results.
Took me a few days of tinkering here and there. Cost me $15 as i had the paint at home.
tools required were:
Files (flat and round)
10mm spanner
flat tip screwdriver (for popping out a few clips)
drill
angle grinder or other cutting device (plasma cutter etc)
bench grinder/snader if possible (you can just use the files)
Materials:
Cardboard
sheet of alloy
Paint if required
First of all was the cardboard model:
Next I bought a piece of alloy, cost me $15 and traced the pattern:
I used the workshop at work and first cut the pattern with all the holes out. I was lucky as we have a plasma cutter at work, sounds fancy but is only good as you are at making a straight cut and requires a fair bit of sanding in the bench grinder/sander etc.
Once all parts were cut and drilled I then made the bend as required.
Once its all cut you will most likely need to make adjustments to get it to fit, cardboard just doesnt represent alloy all that well for the amateur like myself. Metal smith=no worries.
And it resembled the following:
Due to the tool marks and clamp marks I painted mine black (plus i prefer it on the white car):
Before installation:
And fitted:
https://www.sau.com.au/forums/topic/362521-i-made-my-own-cooling-plate/
does this actually do anything?
Yes, it forces all air coming through the grille to go through the radiator, rather than some going over the top of the radiator support; bypassing the radiator completely. Air will always take the path of least resistance
I've often wondered if it would be beneficial to duct the intake snorkel down through the cooling plate to pick up some of that cool air too.
Edited by Daleo
i was just about to attempt this exact same thing for my 34gtt. only ones i can find for a gtt are 150-180+....and they are not worth that much coin. ill post pics up soon as i bash one out. great job mate! looks killer. btw, how did you go about the 90deg bend? and what thickness plate did you go for?
thanks mate
LOl thanks guys,
I Used 1.5mm alloy, its a good thickness, easy enough to work with.
For the 90 degree bend i just marked where i wanted the bend to be, then placed it on the bench with the marks for the bend on the edge of the table and hit the over hang with a hammer (I have a soft head hammer, so it didnt mark the metal). It required a few little love taps here and there once i started fitting to the car, but it come out straight.
THAT LOOKS AWESOME MATE!!!
do have a question tho.. i thought that air for the air filter came from there? i might be completely wrong but im looking at doing somethin similar but addin an air duct in the plate directing some of the air to the original factory air duct..
Cheers
Herbie
The airbox snorkle will just suck air from wherever it can find it :) I think this will restrict some of the cooler air but i doubt it will have any effect.
BTW, looks fantastic! Quite keen to give it a crack on mine now
Cheers
Herbie
Thanks Mate
All the cooliong plates i was looking at like the ARC ones etc etc all run the same desgin i used. I figured if theres runs like that it cant be that bad for the cool air.
I gave it a crack as well, didn't even use a cardboard template.. just measured and drew on the ally.
Shitty camera phone pic at night but you get the idea. Have edged it with some split 4mm vaccum tube and will paint it black when I get a chance to grab some UHT Black.
Will also look at some "wings" to go down the sides between the cooler and radiator (have gutted aircon and mounted 2x thermo fans where the condenser used to be).
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
