hrmm so I went to open it with the remote to get something out, and it wouldn't unlock. Bit of a tick like it was trying, but not enough power. If it was the starter motor that wouldn't be happening right?
  • Replies 91
I won't be home till late cos of stupid buses :( but Pat just SMS'd to say he's left me a jumper pack anyway so I will attempt it.
If this whole saga's just a stupid dead battery I'm gonna be pissed!
Shell, come to think of it if you weren't so dead-set on it being the starter motor and not the battery, I'd have come round at some time to swap my battery into your car and see what happens. Might have saved some time :P
Im dropping Prue off a dinner at around 730 I think....will confirm might be able to swing past fyshsticks if you want.
So wait out and I will let you know
haha yeah that might have been good... I'm a tool :P But srsly, the first grindy noise really pointed towards the starter motor, and the battery's only a year and a bit old? It just didn't seem like that...
Maybe it's both lol
geez by the sounds of it there a million skyline owners in kambah and i never see any of them. damn monsterous suburb
let us know how you guys go tonight, otherwise let me know cos i got my jumperpack etc at home too.
I no has ghey skyline. How dare you accuse me of such atrocities lol
And you don't live in Kambah! lol
Soooooo anyway... car started tonight with teh jumper pack :blush: Doesn't explain the grindy noise but obviously the battery's farked so will replace that and see how we go.
And now I will lock this thread so no one can reply and call me a tool for having a 3 page thread about a stupid flat battery :rolleyes:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
