hahaha unlucky Shell.
nice work zebra, we'll make a horse of you yet
if your battery only lasted a year maybe check to see you got the right CCA rating on the battery for your car, unless you have a smaller battery fitted to clear FMIC piping.
  • Replies 91
Would have been a year and a half, counting back, and the NRMA fitted it.
Thanks so much for offering to come over too, looks like you can do more exciting things on your Friday arvo now :D
Nrma batteries - if it fits in the hole and the terminals are on the right side......its the right battery..........:glare:
yeh no problems at all. damn it now i HAVE to fix the carbies on my VW on friday arvo hahaha
And you don't live in Kambah! lol
Soooooo anyway... car started tonight with teh jumper pack :blush: Doesn't explain the grindy noise but obviously the battery's farked so will replace that and see how we go.
And now I will lock this thread so no one can reply and call me a tool for having a 3 page thread about a stupid flat battery :rolleyes:
Well weak battery maybe meant it didn't have enough power to act against the spring when pushing the gear out to meet the flywheel, yet DID have enough to spin the motor without any load on it.
Yeah could hear the pin engaging but not doing anything else.....then tried again and made the good old rattle gun sound of a flattery, then started on the 3rd go.
(this is all with my jump pack hooked up)
So once it got a bit of juice she fired up :)
Where do you recommend, the Battery Factory or somewhere?
I have Pat's battery pack so I can actually drive it someone instead of having to call them again.
Hahaha all very embarrassing Shell.
Glad to hear it started and it's running now :D
hehe it's ok I'm used to it :D
as Verms said try Lee and Thomas auto electrics aka battery world in phillip. they are auto elecs so if you ask for a battery and mention you not sure the size of the old one is right they should be able to help you out :thumbsup:
im pretty sure they sell GS YUASA branded batteries that have a 3 yr warranty but cos abit more
Went there today... was going to get one of these but they had over-ordered stock of some Optimas that were $200 and so they gave it to me at the same price that the GS YUASA was ($165).
Sooo happy to have my car back working again!!!
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
