hahaha unlucky Shell.
nice work zebra, we'll make a horse of you yet
if your battery only lasted a year maybe check to see you got the right CCA rating on the battery for your car, unless you have a smaller battery fitted to clear FMIC piping.
  • Replies 91
Would have been a year and a half, counting back, and the NRMA fitted it.
Thanks so much for offering to come over too, looks like you can do more exciting things on your Friday arvo now :D
Nrma batteries - if it fits in the hole and the terminals are on the right side......its the right battery..........:glare:
yeh no problems at all. damn it now i HAVE to fix the carbies on my VW on friday arvo hahaha
And you don't live in Kambah! lol
Soooooo anyway... car started tonight with teh jumper pack :blush: Doesn't explain the grindy noise but obviously the battery's farked so will replace that and see how we go.
And now I will lock this thread so no one can reply and call me a tool for having a 3 page thread about a stupid flat battery :rolleyes:
Well weak battery maybe meant it didn't have enough power to act against the spring when pushing the gear out to meet the flywheel, yet DID have enough to spin the motor without any load on it.
Yeah could hear the pin engaging but not doing anything else.....then tried again and made the good old rattle gun sound of a flattery, then started on the 3rd go.
(this is all with my jump pack hooked up)
So once it got a bit of juice she fired up :)
Where do you recommend, the Battery Factory or somewhere?
I have Pat's battery pack so I can actually drive it someone instead of having to call them again.
Hahaha all very embarrassing Shell.
Glad to hear it started and it's running now :D
hehe it's ok I'm used to it :D
as Verms said try Lee and Thomas auto electrics aka battery world in phillip. they are auto elecs so if you ask for a battery and mention you not sure the size of the old one is right they should be able to help you out :thumbsup:
im pretty sure they sell GS YUASA branded batteries that have a 3 yr warranty but cos abit more
Went there today... was going to get one of these but they had over-ordered stock of some Optimas that were $200 and so they gave it to me at the same price that the GS YUASA was ($165).
Sooo happy to have my car back working again!!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
