Hey I was wondering where you guys place your aftermarket gauges?
I currently have my boost gauge mounted at the base of the a-pillar which is barely legal but I haven't been pulled over for it so I can't complain (yet).
I've got an EGT I'd like to mount soon as well as Oil Temp & Pressure (2 x gauges), Air Fuel Ratio and possibly a Fuel Pressure gauge.
All suggestions are welcome. Pics of your gauge placements would be even better.
Car is R32.
https://www.sau.com.au/forums/topic/36324-aftermarket-gauge-placement/
Farkkk...
Too many gauges.
I got three in my centre console GT-R stylin' (oil temp, oil pressure, water temperature).
Boost gauge on column.
I'd like an EGT but that's about it. I suggest perhaps an Apex pen timer with O2 AFR reading included. Ask yourself if fuel pressure and all the other crap is needed.
Water temp. is useless if you have a PowerFC.
T.
I have Autometer boost and A/F gauge jammed at the bottom of the A pillar with Oil temp, Water temp and Oil pressure in the bottom slot in the centre console as the Climate control sits in the top din slot and the stereo sits in the second slot.
In an R32 GTS-t.
good place: air vent on RHS of dash next to steering wheel...
you can get defected for obstructing view or obstructing other instruments so be careful...
Yeah I had thought of placing the EGT there but seeing as I already have trouble seeing the vent whilst driving it's not much use placing a gauge there...
I'm lost...
Guest INASNT
In an R32 GTS-t.
y do u have so many gauges man? u pumpimng out over 600 horses or sumthing??
Nah, I wish, the 3 in the console came out of a mates car when he sold it so i got them on the cheap, mainly because i wanted the oil pressure as the factory gauge is a bit intermitent.
The boost and af meter were out of my old car and i wanted to know what was happening with fuel mixtures when i started winding up the boost. Af gauge is really an indication only but if it's anywhere but full rich when i put my foot down then i know to back off.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
