Melbourne Night Cruise 27th September Friday Night
  • Replies 157
sorry i couldnt make it.... went to a prty... ended up taking all my mates for a little bit of a thrash around malvern.... getting sideways across all 3 lanes.... then back again haha
(when no one was around of course)
Originally posted by funkymonkey
please dun tell me you guys dragged each other down princes hwy
lol
of couse not...i dragged a motor bike and a gold commodore instead! hehehe
...but mainly dragged myself...tends to be a closer race when i do that.
i think there was only 1 R32 there...a gtr r r r arh aarrhhh aahhh...sorry, gotta stop doing that
Originally posted by Dr_Drift
I should've come and waved the R32 flag.... Didn't see any in pics? Were there any....
picz where we met...other then that..nope...
man, I had 2 pour $20 of fuel that night just for that cruise.....that aint that bad :) too bad my friendz R34 couldn't stay hehe...that was a nice drag as well hehe...2 bad my car is still stocky :) alot of work still needz 2 be done 2 my car.....:uh-huh:
and bloody hell u guyz are tall......:eek:
wish you did.. I felt a little out numbered being the only R32...
Good to meet all you guys... hope to make to to the next one.. hopefully my car will have the cam wheels dialed in and been dynoed by then so I will really be be able to thrash it :)
James
James
but mate your car was the biggest beast of all well apart from the 300kw monster of matt
Any pics of your 2dr 510??? Wanna Sell it??
Ah... the 2 door... na.. sorry
With only about 5 of them in Australia that thing is almost worth more to me than the GTR...
It's one of those "long term projects"
it's a bare shell at the moment.... just waiting to finish off some other projects that are taking up the garage space.. then I will get to it...
I've got an FJ20DET and a whole bunch of other goodies ready to stuff in it when I get the time...
When I am finshed with it it should beat my GTR in a straight line... and probably around corners too.. that's if I can get traction :)
Some pics of it before I stripped it are here:-
http://www.ozdat.com/ozdatonline/featureca.../510_2door.html
James
I didn't get home from work until after 8:30, so getting to Nando's by 8:45 was never going to happen, plus it was pissing down and I thought hardly anyone would turn up. How wrong I was :)
So tell me, is there a meet this Friday, same 2 meet points?
  • 2 years later...
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
