all bar 4 of the studs line up between rb20 and 26 on the inlet and i think similar on the exhaust
i also have rear half of r33 tail shaft
and i have a rb25det head that is only any good as a paper weight so you can get the whole lot off me if you want.
PM sent, thanks Damo
hey, chasing r33 front seats, lemme know what you have :)
thanks for your time
ed
I've got some aftermarket ones that'll bolt straight into a 33. They're pretty good. Quite a good amount of support if you want to throw it around some bends and not fall out of the stock sofas :P
has anyone got a cheap air/fuel controller? even the old 5 knob one will do
seeing as im pretty stock i just wanna lean it out down low a little and get some better fuel consumption going (i'll grab a wideband before i start obviously)
drop me a pm
I might know of some 18" rims that'd go on a skyline. BBS Meshies (I think). They come with Khumo semi slicks on them.
off the one that rolled? , in memory they were speedys' or something , but yes they would do , i'm guessing you guys would want more than $400 though :ph34r:
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
