nah the nut was rusted as fark on the rear wiper motor shaft. busted the screen trying to get it off.
Oh.
If you get stuck and need one quick, mine is out and just sitting here, but you would have to find a replacement for it.
Your gonna have to get 4 exact matching tyres for your stag Tom... S2's are super touchy. I had brand new tyres all round in the same sizes on my s2 but differnet brands front to back... and the attessa didn't like it.
Justin.
it seems to be copping it at the moment, the two rears are a few mm off the tread indicators and the front passenger side is pretty screwed (bumped a curb and drove for ages without getting an alignment) but the front drivers side is great!
so if someone has something thats pretty worn too it should be fine
How soon do you need them? I'll have 4 215/50/17s spare as soon as my new wheels finish getting painted and then fitted to my car.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
