Hey ant_32 i have a pair of mirrors in good condition, rubbed backed and in plastic primer, motors work fine etc. asking $100 for the pair. Photos here http://www.gumtree.com.au/s-ad/hobart-region/auto-body-parts/skyline-r32-gts-t-gtr-mirrors-may-suit-180sx-silvia-etc-ex-cond/1001473423
I'm after an R32 2 door rolling shell, must be straight structurally but may consider one with light panel damage or missing panels. If you have/know/hear of one please send me a PM, would be much appreciated.
Cheers,
Michael
Hey guys i have a 32 2 door i might be willing to sell, its black with all sorts of different coloured panels, comes with a vertex kit in ok condition, has no rear subframe though. bodywork is average but perfect track car.
Text offers to 0408 117 171
Cheers, Daniel.
  • 1 month later...
Hey guys, im wanting to buy the following for my R32 gtst:
* Rb26 injector resistor pack
* 34 GTT turbo (or another good turbo upgrade for my rb20det r32)
* some interior plastics/ passenger air vent
* DIRT CHEAP 5x114.3 rims, only gunna be painted and drifted lol
* R32 drivers side headlight
* R32 gtst clear indicators
* Z32 AFM
* R32 gtst coilovers
* Hicas lock out bar and front/rear sway bars.
* Set of 4 spacers, 20mm or so
im on a TIGHT budget, but if you have any of those items, pm me or text me on 0477934063
Cheers n beers.
I can only find ones for R32's, cheers though
http://www.ebay.com.au/itm/NISSAN-SKYLINE-R32-R33-BONNET-BADGE-FIT-GTST-GTR-GTS-/320934361733?pt=AU_Car_Parts_Accessories&hash=item4ab92dba85
thats the one i saw, i didnt know there was any difference sorry mate
