I much prefer the D-jetro option, speak to your tuner though they should have a preference...
Cheers matey im seriously considering going this route and being done with it but my tuner has said that the car will be alot smoother and nicer to drive with normal power fc and afm's as opposed to d-jetro and a map sensor.. How do you find the d-jetro when your holding a certain speed on freeway and when your on off the throttle in traffic etc?
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804279
That sounds like your tuner doesnt know how to tune d-jetro properly, so if you stay with that tuner, use afms.
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804324
Did you get any problems with the Afm's voltage spiking to much under light on/off throttle causing the car to stutter or hesitate and sometimes cause it to stall?
this only occurs if the AFM are too close to the inlet, and reverberation etc.
if its spaced as far as possible, these issues seem not to occur
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804406
agree, djetro and ljetro (ref DVS32R)
both are the same to tune and setup, and i think from memory the djetro takes longer as you have to work so much harder at the transient throttle process more to get it nice, vs AFM that is bulletproof on the factory maps on the powerfc, ie you dont have to focus so much on that area (from no throttle, to light throttle)
both will make same power and response
but will perform differently as far as mapping and scaling are concerned
but back on topic,
you should not max twin Z32s with T04Z
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804875
This is the log from my 460awkw dyno run. 26psi 2530's
The Z32's have some voltage left but the 800cc injectors are out...
Jebuz! Is that on 98? Do the HKS turbos make more power than the -5s? I thought 400awkw was the limit of 2530/-5s on pump.
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5805708
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
