I guess I'm more concerned with the way you worded it, seemed a little to aggressive. I can understand petero'nell sending something like that but all you are going off is one guy on a forum who got a dodgy deal. His eBay feedback is good.
Well I've been ripped off plenty of times before on Ebay and doubly shafted by PalPal and there BS money back guarantee so don't have much respect for the site or it's many dodgy dealers.
If you agree that Petero'nell got shafted by this same guy and take into account the fact that I had just bid (i.e. committed) $400 for the same product from him then why wouldn't I be a bit pissed off? It's only an email FFS and if he is legit then he has nothing to worry about!
To be honest I'm not convinced that they aren't what he says they are... he has explained why they have tool marks on them (which I had also already mentioned in this thread i.e. during the flow testing process that he does - not the JECS factory) but I don't understand why he needs to re-test them surely they all come out of ther JECS factory within 1 or 2% of each other anyway.
In the guys defence he could be buying bulk lots that don't come with fancy packaging and warranty cards as these things are for retail only and not bulk products supplied to the trade.
P.S most people complete the feedback on reciept of the goods (as Ebay and the vendors keep prompting you to) not many wait until they have installed and tested the product weeks or months later. I think this can skew the results for products like this, once you have left feedback you can't do it again or change it.
bingo. if they are genuine brand new JECS why would they need flow testing by him?
Plus, any place with a half good manufacturing procedure wouldnt mark their goods in the testing phase.
I bet he just says 'marks from the flow testing' any time he is queried n people always just accept it or suck it up.
Bang on the money there jjman!
I asked him to prove conclusively that they were factory 550cc JECS saying that if he could he would shift a lot of them through SAU and he just came back with that same old tired line...
Becasue of my "aggressive" email (LOL) he cancelled my auction bid (so that worked and I'm off the hook!) and I have ordered me some Tomei 555's.
It sounds like you are going to use these injectors anyway and by rights they should do the job fine but you have been wronged big time!
It's always the same old story with Ebay; buyer beware and even when you are you often end up losing out anyway...
Good luck mate
To ensure consistency. You have assumed that each injector off the production line flows the same.
The thread linked below contains comments that ID's are sets of bosch's that have been flow matched. No reason to think JECS wont suffer the same variability.
"They are ID ones by the looks of the extender, Keep in mind they are only Bosch injectors flow matched and tested, I asked the guys at AZNEW today when I ordered my proflow fittings, they said theirs come in Bosch boxes and are unmodified. "
"I had a bad experience with the bosch 2000's one injector flowed 7-8% more at idle and fouled the plug real bad.. Im guessing injector dynamics found the same problem and is probably why they push the flow matched sets that you pay a premium for.. "
http://www.skylinesaustralia.com/forums/topic/361011-will-my-sard-700cc-injectors-support-400awkw/page__st__40
Totally agree with you however I bet these guys could produce some invoices, packaging or something to prove that the injectors are brand new bosch items.
Our friendly Ebay dealer can only talk the talk; he can't back it up with any evidence or proof and he has been given a couple of oppurtunties now.
Maybe he is being honest, maybe not... I am personally not willing to gamble $400 on it.
Good luck to anyone that tries... please let us know how you get on
http://www.skylinesa...kw/page__st__40
  • 6 months later...
There must be an OEM-Number on these injectors, right?
So wouldn't that number give some clues?
I ordered EV14 injectors from the same seller, and the items seem to be OK.
In fact they are Ford Motor-Sport injectors, for the GT500 Mustang (made by Bosch).
The seller wouldn't say so, so I presume they fell of a lorry or something ;)
  • 5 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
