Hi guys, bit of a long shot here, but I am looking to test out an Fcon V-Pro v3.2 or v3.24 on my M35 Stagea.
Long story of which I won't bore you with the details, but I am hoping someone in Vic has one of these that they would be willing to loan out/rent out to me for a couple of weeks to see if the ECU throttle restriction can be bypassed by using a V-Pro.
Serial # FCP020001 - FCP030000.
Anyone?
https://www.sau.com.au/forums/topic/364094-borrowrent/
whats the restriction? is it based off TPS?
i cant see the FCON letting you intercept the TPS and cap it
check out how DAN666 beats the ER34 one
it has a similar "feature" where the ER34 panics on mega throttle
theres some cap by pass thingy he worked out
https://www.sau.com.au/forums/topic/364094-borrowrent/#findComment-5810747
The M35 electronic throttle wont open past 26% at takeoff. This is only until 30kph where all hell breaks loose. Fine with the stock turbo but my GTX wont spool at all, even with the 4k stally.
Read this thread if you are interested in our PITA throttle issues.
http://www.skylinesaustralia.com/forums/topic/266854-m35-emanage-ultimate/page__st__340
https://www.sau.com.au/forums/topic/364094-borrowrent/#findComment-5810784
oh wow its drive by wire
gotcha
well the only way to bypass that is to give that sensor or logic a bullshit speed reading, ie always 37km/h
but who knows how you would do that or how you would bypass it, its probably from the main ecu itself
good luck with the fcon
https://www.sau.com.au/forums/topic/364094-borrowrent/#findComment-5811718
The ecu has no speed input wire, it all goes down the CAN line. If it were easy I would have done it believe me.
There are a few options we have, some have panned out and most have not. The F-con may work if it adjusts the throttle as it is the only supported aftermarket ecu with base data.
I am going down the cable throttle route with the Emanage, it works and runs the engine fine (in limp mode) but the eVTC cams stay in full retard and I have no kick down signal to the gearbox. Not too big a deal but its a pity the Vmanage didnt work properly.
https://www.sau.com.au/forums/topic/364094-borrowrent/#findComment-5812132
https://www.sau.com.au/forums/topic/364094-borrowrent/#findComment-5812372
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
