  • Replies 53
Same stuff really internally.
Differences are mainly ignition. R34 ignition setup is prone to failing, R33 setup is better.
You also need IIRC a R34 PowerFC for instance to go with a R34 ignition. Paul will remember I'm sure.
Other stuff is mainly visual with different cam covers etc.
IMO you should get a 33 motor if you need one to put into a 32, all your existing stuff is changeover basically with you stuffing around. ECU will work as well.
more less likely to fail would be BNR34 RB26 as it's not as old - given reasonable km usage etc
BNR32 and BCNR33 use same ECU control
BNR34 has minor differences in the ECU, most notably is the ECU socket wiring is different (and built in immoboliser as part of the ecu) - no idea how that works with the PFC
vspec as far as i recall has differences to suspension, 4wd computer logic and other handling characteristics
not aware of engine internal differences
Cool
Just looking for the bare engine
Will an r34 engine completely bolt up to all r32 intake, exhaust and accessories with no drilling, grinding, bending, welding, dremelling, bashing, kicking, praying and cutting?
Thanks
Everything will bolt to it no problem except the the crank angle sensor and the diff ratio is different due to the 34 having the six speed box, so make sure you use the r32 sump
Edited by r32-25t
couple of points (this has all been covered before btw).
there is no difference between 34 vspec and 34 non vspec engine wise (or turbo wise for that matter). same goes for 33 V-nonV.
34 engine vs 32 and 33? cams are different, 34 cams slightly longer duration and also the CAS drive on the end of the cam is different (so for 34 cams you need 34 CAS and so on).
coolant pipe on intake side of the block is different (easy to swap).
heater hose pipes on rear of the block are different (again easy to change)
diff ratio is different (easy to replace the whole sump with a 32/33 sump or your old sump)
ignition set-up is different with 34s having ignitors built into each coil-pack (32/33 have same set-up with ignitor mounted at the rear of the coil-pack cover)
there is no difference in how manifolds fit up on either intake or exhaust side. no difference in engine mounts either.
you can easily fit any RB26 engine into any model GTR with very minor stuff to address.
Thanks everyone.
I bought an R34 RB26 from a VSpec. The only thing missing is the CAS as Beer Baron advised above.
Are the R32 and R34 RB26 exhaust cams the same? Should I just swap them if they're the same, or get another CAS if they're different? Also, how do I identify if I've got factory or aftermarket cams?
Cheers
my advice would be just buy an R34 Cas and do the wiring mod to get it working in your R32.
otherwise you'll need to fit an R32/33 cam to the head (no problem doing it as there is no physical difference in the head) and then you can run your 32/33 CAS no problem. to me, it's easier to buy an run the 34 cas.
as far as standard cams go pretty sure R34 exhaust cam is longer duration (same lift) compared to 32/33 cam. inlet cams are same.
heaps of difference. 34 ATTESA ECU has much higher sampling rate than 32 does. possibly has improved logic too but the sampling rate improvement alone is significant. on top of that the ETS pro from the VS II/N1 etc R34s is better again. especially noticeable in a circuit car.
also 34 (and 33 for that matter) ATTESA is set to keep some pressure in the transfer case all the time which makes it seem more responsive/quicker acting too.
Do you know what the sampling was? I remember reading moons ago something along the lines of:
R32 100th of a second
R33/R34 1000th of a second
So quite different a long with the pressure etc. Hence you cant just fuse pop a 33 :)
yeah that's about right. sampling rates are massively improved. hence why just sticking the ets pro into a regular 33/34 gives a noticeable improvement on the track. you'd be hard pressed to tell on the street though (between regular 33/34 and ets pro that is).
is there a difference in the actual mechanical operation between the 32 and 33/34
I know the system is changed between models obviously, but what I'm sort of asking is the upgrade merely on the software and hardware end of the operation or are there physical changes to the system that form part of the bonus.
Obviously there is a lot to be gained in making the 32 upto par with some of the other models considering the substantially disparity in sample rates.
I don't actually know the answer but I would say it is almost certainly just a software upgrade, there were huge improvements in computers over that time frame and the mechanical pumps are analog so they can be turned on and off as fast as you like, it is the computer actually being able to do the calculations in the required time that is the difficult bit.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
