Hmmm...
maybe I shouldn't be surprised at seeing...
* a black R35 GT-R
* around Windsor with...
* POLICE livery
an actual, or are we talking the same one that did some of the tarmac rallies in police livery?
The maintenance costs would kill the police force budget... might have to ask a buddy who was recently involved in their fleet arrangements etc.
https://www.sau.com.au/forums/topic/364752-mystery-car/#findComment-5819691
It's not like they really need them for high speed persuits, the F6's will more than take care of that.
Unless they are after ram raiders although i haven't heard of many of late either?
Maybe they are going back to the days where they used to run the police drag car and doing motorsport events in it as a PR thing?
https://www.sau.com.au/forums/topic/364752-mystery-car/#findComment-5820585
Nice use of tax payers money.. :rolleyes:
:down: :down: :down: :down: :down: :down:
If they have one, it would have most likely have been given to them by Nissan.
Some stations have an RX-8, but it was just given to them by Mazda. You can't perform any real duties in it apart from taking it to a promo/fair event for kids etc.
Pics would be good.
Edited by RB25PWR
https://www.sau.com.au/forums/topic/364752-mystery-car/#findComment-5820914
Pics would be good.
With the way Nissan behaves I doubt they would have given it to them..
https://www.sau.com.au/forums/topic/364752-mystery-car/#findComment-5821153
Its got lights and if you look hard enough its even got the word police written on it (boot lid, near nissan badge)
what more do you want???
2 fat guys and a box of donuts?
oh right, nsw police... brown paper bag..
https://www.sau.com.au/forums/topic/364752-mystery-car/#findComment-5822177
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
