I was looking at the gt3076 kit at gcg for $2990 but not sure if it's worth the extra $1000
Brand new genuine Garrett GT3076R
http://www.nzperform...ewCat&Submit=Go
with the exchange rate it would be less than the GCG highflow even with postage. You can run the wastegate directly off the exhaust housing and plumb it back into your dump. It will easy make 300kw at 20 psi but you will need a wastegate, injectors, z32afm and a nistune. Stock manifolds will be fine although you may need a 10mm spacer for the turbo.
And just as an aside - our local turbo guru prefers bush bearings! -Says they are more reliable and much cheaper to rebuild.
  • Replies 205
It is looking like a good option, will it be big enough for 400hp?
Hell no. PM sent. You want 400hp, take note below.
I've had stock turbo, high flow, HKS 2530, and now Garrett 3076 ... and I say don't mess about and do straight to the 3076.
The 2530 will run out of breath. Always found myself wanting to grab the next gear, before anywhere near the redline, because the turbo was running out of breath. My 3076 just keeps pulling and pulling thru the revs. You WILL NOT be disappointed with the 3076. 2530 will not get you big HP, the 3076 will. Invest your money in a new 3076, rather than second hand (unknown condition) 2530.
There are a fair few Z32 AFMs getting around now on SAU and Ebay for the $100 mark. And I also picked up a new set of 555cc injectors for Neo motor for under $600 ... I can give you the details of the bloke who got them for me. Together with a Nistune (or other aftermarket ecu) you can chase big power (depending on your exhaust and other mods of course). So all up $2700 got me 252rwkw, or 338hp at the wheels ... thats like $8 per hp.
My tuner finished off my tune on thursday actually, and I'm getting 252.6rwkw @ 16psi. Tuner wanted to go to 18psi as he reckoned 280rwkw was easily attainable with a bit more time ... thats 375rwhp, so not far from your target power!
I'm told my 3076 can go to and hold 22psi ... thats around the 320rwkw mark ... thats 428rwhp in the old language.
Get a new (under warranty) 3076. Enuff said :P
Ok so after reading stuff I've got a list sorted out, rough prices if I find them cheaper that's even better, gt3076 $2950, z32 $300, nistune $800, sard injectors $???. I've already got a k&n panel filter ( it sucks the xmas tree clips and bonnet lining in so I might need a pod ) , hks 3" high power cat back/+ custom drift pipes if I want, jjr stealth front mount. Anything else I will need?
What's with the VW? Is that the alternative?!!
What do you get from GCG for $2990?
The GT3076R from the link above (NZ Performance ) works out at AU$1662.00 at the current exchange rate so even with postage and tax (if any) I would think there would be a decent saving.
If for some reason you must have an Australian supplier try sending this guy an email before you fork out $3K:
http://www.streettotrack.com/
sorry i added the wrong image code, thats my wifes car, was supposed to be the turbo still together lol. but anyway, i did consider that gt3076 from nz but its an extermal gated turbo and i cant really afford to shell out for a new manifold/dump pipe
my dad is pushing me toward sthe gt3076 kit form gcg, and it looks like the easiest option aprt from getting my turbo turned into a 30/76 at mtq
my only problem really with the gcg setup is i need to buy a new dump pipe as its a 5 bolt rear not a 6 bolt.
GCG should be supplying one in that price. You do not want to compromise with a non-garrett turbine housing if you want to get the best results.
ive got a bellmouth dump so i cant use the dump that comes with it without buying/making a new pipe.
zebra - when you spin a ball bearing turbo backward they seize. ive seen it happen twice.
cre8tor - the beetle is quicker then my stagea :/
my mate had a forged 33 running the same turbo with all the supporting mods
280rwkw on about 17psi i think
so i'd guess so cos thats 375hp
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
