I was looking at the gt3076 kit at gcg for $2990 but not sure if it's worth the extra $1000
Brand new genuine Garrett GT3076R
http://www.nzperform...ewCat&Submit=Go
with the exchange rate it would be less than the GCG highflow even with postage. You can run the wastegate directly off the exhaust housing and plumb it back into your dump. It will easy make 300kw at 20 psi but you will need a wastegate, injectors, z32afm and a nistune. Stock manifolds will be fine although you may need a 10mm spacer for the turbo.
And just as an aside - our local turbo guru prefers bush bearings! -Says they are more reliable and much cheaper to rebuild.
  • Replies 205
It is looking like a good option, will it be big enough for 400hp?
Hell no. PM sent. You want 400hp, take note below.
I've had stock turbo, high flow, HKS 2530, and now Garrett 3076 ... and I say don't mess about and do straight to the 3076.
The 2530 will run out of breath. Always found myself wanting to grab the next gear, before anywhere near the redline, because the turbo was running out of breath. My 3076 just keeps pulling and pulling thru the revs. You WILL NOT be disappointed with the 3076. 2530 will not get you big HP, the 3076 will. Invest your money in a new 3076, rather than second hand (unknown condition) 2530.
There are a fair few Z32 AFMs getting around now on SAU and Ebay for the $100 mark. And I also picked up a new set of 555cc injectors for Neo motor for under $600 ... I can give you the details of the bloke who got them for me. Together with a Nistune (or other aftermarket ecu) you can chase big power (depending on your exhaust and other mods of course). So all up $2700 got me 252rwkw, or 338hp at the wheels ... thats like $8 per hp.
My tuner finished off my tune on thursday actually, and I'm getting 252.6rwkw @ 16psi. Tuner wanted to go to 18psi as he reckoned 280rwkw was easily attainable with a bit more time ... thats 375rwhp, so not far from your target power!
I'm told my 3076 can go to and hold 22psi ... thats around the 320rwkw mark ... thats 428rwhp in the old language.
Get a new (under warranty) 3076. Enuff said :P
Ok so after reading stuff I've got a list sorted out, rough prices if I find them cheaper that's even better, gt3076 $2950, z32 $300, nistune $800, sard injectors $???. I've already got a k&n panel filter ( it sucks the xmas tree clips and bonnet lining in so I might need a pod ) , hks 3" high power cat back/+ custom drift pipes if I want, jjr stealth front mount. Anything else I will need?
What's with the VW? Is that the alternative?!!
What do you get from GCG for $2990?
The GT3076R from the link above (NZ Performance ) works out at AU$1662.00 at the current exchange rate so even with postage and tax (if any) I would think there would be a decent saving.
If for some reason you must have an Australian supplier try sending this guy an email before you fork out $3K:
http://www.streettotrack.com/
sorry i added the wrong image code, thats my wifes car, was supposed to be the turbo still together lol. but anyway, i did consider that gt3076 from nz but its an extermal gated turbo and i cant really afford to shell out for a new manifold/dump pipe
my dad is pushing me toward sthe gt3076 kit form gcg, and it looks like the easiest option aprt from getting my turbo turned into a 30/76 at mtq
my only problem really with the gcg setup is i need to buy a new dump pipe as its a 5 bolt rear not a 6 bolt.
GCG should be supplying one in that price. You do not want to compromise with a non-garrett turbine housing if you want to get the best results.
ive got a bellmouth dump so i cant use the dump that comes with it without buying/making a new pipe.
zebra - when you spin a ball bearing turbo backward they seize. ive seen it happen twice.
cre8tor - the beetle is quicker then my stagea :/
my mate had a forged 33 running the same turbo with all the supporting mods
280rwkw on about 17psi i think
so i'd guess so cos thats 375hp
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
