Ya get me form I faxed last week?? or is it a fail?
Got it, you sent it upside down.. i hate you :P
Guys, looks like i will be out as the GTR is sold and i wont get a chance to replace it with something worthy of racing
you can always take the company car hehehe :whistling:
  • Replies 436
Posted Images
Damn mate, i was looking forward to catching up with you as well :( Good that you sold the car though :D
Surely one of Jean's brothers has something that you could have some fun with?
i paid last week my 2nd entry fee but my names not on the list...........yet.
how many more entries are needed to make this day go ahead??
also as a couple others asked, is the burnout pad available too during the day? im sure most will get alittle board racing for 7 or so hours
Tech question, with the Battery relocated to the boot, do you have to have an external isolating switch fitted?
andra rule book says, any vehicle where the battery has been relocated
, require a battery isolation switch.
but saying that, ive got two mates with 12sec cars and boot mounted batteries without an iso switch and they have never been told they cant race
No company car atm, have been thinking about bringing the 120Y wagon out there but i'm not sure whether anyone (or the gearbox) is ready for 21kw@wheels of fury!!
Would be good to catch up sometime soon.
I get the feeling the other combo may soon (hopefully) be running too quick for this event without a cage so thats a no go either.
I wouldn't worry too much about your stuff spesh with an SAU crowd. We've come up on Wednesday nights as a group from the ACT several times and we've left sets of tyres, trolley jacks and all sorts of expensive items out and its never been touched.
Not for irregular off the street competitors.
It is required for vehicles faster than 11.99.
Hey fellas, I don't know if WSID will let us run our GoPro's but I have the three for the club up for rent. Is $35 paid on the day. That includes me making DVD copy of the video files and mailing them to you about a week after the event.
PM me for reserving one. First in, best dressed.
So is that gospel then? have run a 11.92 previously, hoping to run quicker this time.
Do i need to hook up something or will it get through scrutineering ok?
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
