:action-smiley-069: Hi Guys and Girls...
Just need to know what mods is essential to drift R33 skyline GTS-T .......... I want a drift setup in my skyline not for proffessional use but just if i go on track so i can drift my car properly with full control and less body roll......... was watching few videos on you tube and these guys were amazing ........... Just need to know that do i have to change the DIFF as well ???? and as i think need some power at the wheels as well so how much RKW at least i need to drift my car easily........... do i have to buy coilovers as well ???and whtat other mods i need ???? so if anyone can help me with this setup then it will be highly appreciated ....thanks
coilovers, ~8/6 for street/track or ~10/8 for track drift only
swaybars - whiteline adjustables or selby's are an easy option
diff - you can buy a locker from kaaz USA fairly cheaply at the moment
at a minimum this will make it a lot easier to control
thanks guys for your replys.............. but how much KW at least i need at the wheels ........ as i think this is the most important one............ and how much all up it will cost me (Drift Setup) ,.............Thanks
Most of the guys on here who are involved in any kind of motorsport, rallies, circuit, drift whatever will tell you that suspension and body control are not only more I mportant than power at the wheels but you will achieve a greater improvement for a lower cost, so as above start with a diff, 2 way is best but u can get the diff shimmed to lock it up as a start, coilovers,and some stiff swaybars, costwise it depends how far u want to go and how much u can do yourself, probly 2000 will get u some 2nd hand coilovers a shimmed diff and a rear sway bar probly with change.
for basic drifting you need 200rwkw
imho sell your car if its stock and buy a modified GTST already with this power level
otherwise
going from stock to 200rwkw + basic drift setup
ecu 1000
tune 500
exhaust 1200
tyres 600
suspension and diff setup 1000
new diff 1000
good intake 350
boost controller 300
intercooler 600
fuel pump 300
clutch 1200
doesnt include coilovers
doesnt include new diff
should get some change from 10k
be prepared to bin your car and if its your only car rethink if you are ok with loosing your car
many have done so before
Power isn't important at all.
Skill & car setup are far more important than power.
you could get away with just an ecu, exhaust, fmic, clutch and suspension no worries
nistune - 800
2nd hand fmic - 300
hd clutch - 500
2nd hand coilovers - 700
2nd hand swaybars - 200
welded diff - 100
R32 actuator - 20
that's $2620 for a fairly easy to drift setup that should yeild ~180rwkw
but as has been said, power is not that important for drift, it's all in the suspension and handling setup
my ke70 only had like 70rwkw and it was easy enough to slide
hi Guys,,,,,,,,,,
Thanks for replys and great help............. Yes, I got pretty much stock car at the moment......... Only Mods are FMIC , Exhaust , BOV and I just did a dyno run and it was 165Kw ............ So i decided to buy the Coilovers and aftermarket ECU.................. The list of stuff that is sitting in my Garage is as below
1. Tein HA Adjustable coilovers (Second Hand) ----- $800
2. Apexi Power FC (Second Hand) ----- $1000
3. Apexi Electronic Boost Controller (Second Hand) ------$450
4. Apexi air filter kit (Second Hand) ------$350
5. Defi Guages (Boost and Oil Pressure (Brand New) ------$400
6. Autometer Tacho (Brand New) ------$200
All this stuff is sitting in my garage collecting dust as I spended all my saved up money to buy this suff and now i don't have enough to put them in......... Anyways, the only things i have to buy now is Two Way Diff and Sway Bar according to you guys to complete Drift Setup............ Any good place in Victoria where I can take my car and all the above mentioned stuff and other stuff (Diff and Sway bar) to put them in OR Sell this car and all that stuff and buy a Modified Skyline................. Any recommendations??????????????????????????????????????? Thanks
Hektik points are good for rwkw you should know that by now Paul. Also, they will match his veilside kit :D
as for Recomendations, put all the stuff on your car and go sliding, if you want some more power ( and I would too ;)) get turbo hiflowed with steel wheels so it can handle 18 pounds of boost, about 1000$, plus tune will be 500+ this will give you plenty of power (210kw) for learning and one thing nobody has mentioned strangely enough, a hicas lock bar, which is probably more impotant than anything else.
otherwise
ecu 1000
tune 500
exhaust 1200
tyres 600
new diff 1000
good intake 350
intercooler 600
fuel pump 300
clutch 1200
nistune - 800
2nd hand fmic - 300
hd clutch - 500
welded diff - 100
R32 actuator - 20
ya'll tripping.
my car slides fine stock power, fmic,exhaust thats it.
weldy, coils,swaybars,solid bushes or whatever there called 2 drift days not an issue.
clutch is still going strong. Just get out there have a crack mate dont worry about these high rollers.
thats the best advice yet alr33x :thumbsup:
another thing I forgot to mention why not just fit all the stuff to the car youself, there is plenty of info online how to do stuff. I dont know what im doing but I reckon I could fit most of that stuff in a weekend with some help from my old mate google
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
