  • Replies 3.6k
Posted Images
Yep only 19 Z-Tunes ever made, they are basically hand built by Nismo. Only around 5,300 34 GTR's ever built of any kind, which is also pretty special!
get it right, 20 made...haha
all used cars from the start too, no new cars used..... they used low km cars in perfect nick then modified them to Z spec.
they run about 200-300k last I saw one. a big collector car for sure.
holding out for R35 with a manual gear box...lol most likely be a V8 in 2 years anyhow. based upon the dirt in GT1
good thing about R35 they make a butt load of goodies since it was sold in the states, dual superchargers and turbos on the same car, insane madness!!!!
did anyone see the old school skyline . molded on the new school stag. if I can dig up a photo it was interesting
You mean this one?
Don't be like that Ruby. Well you are satisfied with driving a Volvo :P
That pic did the rounds in the Stagea section a year or so ago, and many people were ill, suffering nausea, panic attacks, or just plain hatred to such a cruel act. :P
It is 19 built for Z Tunes, that's from the horse's mouth (that would be the horse in Omori ;) )
If you're holding out for an R35 with a manual box, you'll be holding for a very very long time.
Speaking of Z-Tunes. There is a build thread here on SAU from a guy 'Bobby....' who had a Z-Tune and sold it to build The Ultimate GT-R from what he calls it. Custom built everything, pretty big build thread and alot of haters aha
So, my old mate just passed on the message from the insurance company about the accident I had a couple months ago that wrote off the Magna.
The other driver has been found at fault.
Awesome. Now I can stop stressing.
Had an interesting wiring job today. Went to connect up SLEDs shed into the meter box and I blew the ETSA service fuse :whistling:.
I came from work so I was in my ETSA uniform so when ETSA rocked up to fix the fuse I was trying to hide from them so they didnt see my shirt. So SLED disguised me as a mini SLED and I left out the side. Thanks for the jacket. :thumbsup:
Anyway glad you now have power on the shed SLED
haha, no harm done as it was fixed pretty quick.................It was one of the 3 Phase 80 amp fuses....equivalent to about 20,000 watts I reckon >_<
Thanks for the help Brad....nice to have somewhere else to polish the bike now as well
ROFL
top work brad :P howd u manage to blow a service fuse?
No thanx already got 33 gts-t fronts and rears and going alright with the EBC green pads, Just wanna upgrade the booster and bmc to get me some better feel. Plus as everyone says Mallala is all about brakes.
Would they still work on the 13 Luke as its a non ABS car??
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
