  • Replies 3.6k
Posted Images
sled nice taxi ull be amazed how agressive the little turbo on the xr series pulls they max out at 320ish but thats the most impressive rollons ever with a zf u did get a zf didnt u ? or u go stick :rolleyes:
one of the blokes had a ego one 320 on tolly did a 12.2 @119mph but on the street got car lenghts on any of us at 60km/h on wards weapon 4 sure :thumbsup:
On the dyno with stock ECU I'm assuming? I've never checked to be honest...
Needs a tune pretty bad, getting an absolutely horrible amount of k's out of it.
There's no tuning that you can do with a stock ECU. The only thing that you can do it adjust the base timing at the CAS and anyone can do that with a timing light. If your fuel mileage has become worse then i would be looking at your O2 sensor.
Sorry bud, here you go:
Specs to follow via a Dyno Sheet next week when it goes to Willalls so Martin can work his magic
Really looking forward to this SLED. There are a lot of new techniques in the tuning of these cars that arent being implemented in South Australia currently. I know this as none of the SA Tuners attend the Australia wide advanced Ford tuning workshops....and I am the headmaster :)
Your tune will have 'all the fruit'
Also prob won't hurt if you changed the plugs and done a service at the same time, ie oil, coolant, filters, give your intake filters a good clean. That should get your car running just right :D
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
