  • Replies 3.6k
Posted Images
We were asked/ordered by SAPOL to take down the thread about the cruise, the subsequent thread and all references to the event. Even they don't like how the news/ACA grab hold of these things and publicize the hell out of them - it actually makes more work for them. Various media outlets were hounding them daily for more details, and they were browsing SAU constantly for info. Best solution for all import owners is not give them any ammo.
and on the note of ammo, I just deleted 2 stupid posts from the "Spotted Thread"
why give even an inch to the law makers and media when we're trying so hard to keep up appearances (so to speak)
An off the cuff post (that may seem innocent) can have long term efects as to how all of your rides are viewed by Sapol & the media
If you have 1/2 a brain in your heads, engage it before posting :wacko:
Figured as much. Probably wasn't the smartest thing to post on Youtube. We had an event in WA on Sunday called 'Rising Sunday' - similar to All Japan Day. WAPOL camped out near the exit and defected around 20 cars..... things aren't much different over here to SA!!
Skip to 55 secs for the 'Hoon Report'!
Edited by 32godzilla
dont you guys realise that no matter how you play this. which high road you take.. that the cops and not to mention the pollies and poweres to be have already mapped out how its going to play out.
they are talking about putting in a recommendation to the magistrae that the cars be forfieted.. all because of some public f**king image.
i dont care what opinion you all take on the guys that did the tunnel runs but this is just a f**king bullshit abuse of power/governmant.
thats my rant for the night.
so by your definition Simon, doing the opposite (ie run a muck on the roads and put all sorts of shit on Youtube) wouldn't make any difference then
We all need to be wary of what ammo we give Sapol & the Media.......to say it won't make any difference is not realistic unfortunately
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
