  • Replies 3.6k
Posted Images
still more in it steve lol.
luke: yeah i know i had a list of ppl who missed out... and yeah for sure come for a ride!
yeah figured you would have, well put my name on the list for next time then :D
yea, bit of a woops on the skid pan, dunno how either lol,
just panel damage, nothing sticky tape and cable ties wont fix :-)
lol at iron chefs corner, scared the f**k out of me when it started looping i immediately thought " that wall looks pretty hard"
but all good, managed to slide that bend pretty consistant for rest of the day.
tax cheque is now spent before i even get it lol, partially on simon modding my knuckles! much needed! and solid cradle bushes, and a tune.
heres a vid on the skid pan with adrian as passenger, fabs in front,
I was pretty impressed at how hard people were going round 'Iron Chef Corner' and the straight following.
its pretty fun when its wet, limiter in 3rd with only 140kw, no chance at doing the whole corner in the dry with my car tho
Tailem ran a 400m event last year (September if I remember right)
It was good enough for my EVO X to run an 11.9
and a mates turbocharged LS1 a 12.2 (on Achilles street tyres of all things)
Now apparently its unsafe to run cars 400m there - although the surface was totally fine, CAMS even let us run in the wet, and there was no problem with that either. Let the Sporting Car Club run these meets and they will be 400m. For some reason ANDRA seem hell bent on making everything into an 1/8th mile....we already have four such tracks. We do not need another.
Standing 1000m would be even better. The deep end is where the fun is.
For a cheaper sport, try knitting, not castrating drag racing.
Twenty 20 short format suits cricket, not cars IMO.
Lobby the Sporting Car Club and we will get the 400m events back :)
Truer words have never been spoken.
I might head out for some runs at this 1/8th mile thing in August just for a look (haven't been to the TB track before), and for some legal tyre warmup burnouts (assuming they are still allowing THAT)
I just ran my car in hicas diagnostics mode and it flashed once but nothing else (to my understanding that tells me there are no problems) am I correct?
Car is 93 r32 Gtr with standard steering wheel and all that jazz..
Another happy Matsuri customer here! Spent a bit of time in Daves car and alot in Brads, was gonna find Craig for a run but couldnt find your garage haha.
Few cars a bit sad and sore afterwards, especially that s13 that rolled!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
