  • Replies 3.6k
Posted Images
were getting hung out to dry because were red blooded australians next bbq's in summer will attract a carbon tax :rolleyes:
fknoath mate, definately if you burn the snags!!!!
its beyond a joke now.
yeah I agree.....anyone who orders steak "well done" in a restaurant should def be subject to carbon tax :nyaanyaa:
so whose celebrating a new tax added to there outgoings :ermm: do i get anything for it :ermm: so wheres it going again :ermm: i just got screwed didnt i :laugh:
i'm looking at fitting a 32gtr diff center/housing into a 32 gtst, is there anything vastly different??
axle bolt pattern is the same??
thanks
"Can anyone confirm of a 32 GTR diff will go straight into 32 gts-t?"
"Axles will be different 6x1 on GTR yours is probably 5x1"
http://www.skylinesaustralia.com/forums/topic/300593-r32-gtr-diff-into-gts-t/
The GTR will have a CV on the nose of the diff and the GTS-T will have a uni joint.
When the S-Series guys have put a GTR diffs in thier cars they have swapped the whole cradle, i think the mounting point are different, haven't looked into it personally though.
Does anyone here have contacts with the towbar industry? Need a decent towbar fitted cheap for my daily 2010 Subaru Forester X. Was bidding on some on ebay, but they are all interstate, and I'm becoming more and more lazy these days.
yes, but can only tell you when i get home as dont have details with me
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
