  • Replies 3.6k
Posted Images
got a Garrett 2876r .64 offered to me for cheap as chips....
anyone know what it would be like on a 20? had a quick search, confusing results lol
I've heard they are no good on 20's. 2871 is the one you want. I think it's the 2876 that's a weird turbo, like the inlet and exhaust turbines are out of proportion, as a result it either has tonnes of lag, or no top end, can't remember.
yea, but then the occasional person reccomends as a good turbo for a 20....
im taking it to mtq tomorrow see what they say?
They are a bit of a dogs bollocks of a turbo. As others have said they are a mismatch. The 53.8mm turbine is even a bit to small for the 71mm compressor with a 2871 so with a 2876 you have the extra lag of the 76mm compressor but with no extra power to be made because the 53.8mm turbine is that limiting factor.
There are a few uses for this turbo but they are not conventional setups; like they are good in motor sport classes where you have a restrictor plate that limits the amount of air flow available to the compressor.
Garrett even give you a heads up on their info page for the 2876 where they say;
* Best suited for unique applications such as asymmetric turbo installations
* Not recommended for general performance applications
Edited by D_Stirls
Funniest thing happened the other day.
I was coming home from TTP back to Lobethal and I was going past Inglewood towards Chain of Ponds.
I was stuck behind this RED Commodore with; Chev badges, aftermarket HSV kit, racing stripes over the body, and 20 inch rims.
He was going very slow and once given the opportunity, I ,quite quickly may i add, overtook the commodore and continued on my way.
I then got to the intersection of cuddlee creek rd and tippett rd (behind the dam) and low and behold there comes the commodore screaming up behind me with what appeared to be red LED's on the front of the lights like some sort of angry demon.
I then turned off at the cafe at Cuddlee Creek when the bloke slowed down and i then copped an ear bashing about driving "jap crap" and the extent of his intelligence then came out with "skylines are for poofs, get a commodore!!"
He then screamed away with his V6 with some sort of exhaust changing gears manually in his auto car.
EPIC :stupid:
Yeah i had some guy on my ass yesterday in a VT/X with a VY bodykit, some shitty rims, the guy had on white frame oakleys at 5:00pm in winter with a singlet. Speaks volumes really.
just received a phone call from my local member of parliment - amanda rishworth - asking for my thoughts.
quite simply had 2 comments to make, first of all Adelaide NEEDS a motorsport complex, and secondly the rate of the pension (barely) covering costs of living.
She said she would be writing to the Govt. to push for the motorsport complex and would follow it up & eventually get back to me.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
