  • Replies 3.6k
Posted Images
Can anyone tell me where to find on the world wide web the ride heights for r34 that regency allow? Wana keep the boys In blue happy with the height Thanks
It's been covered in the defect thread before .. I have an old copy of the stats here - pretty sure it's still accurate for R34:
any idea how i can get a engine block from the US to Aus?
which part of USA luke? there is a place on sir bradman drive that runs freight logistics from the west coast of USA . its not cheap or fast . you must palletize the engine on metric pallet then weigh it, a plastic pallet saves you the trouble of spraying it for bugs on arrival in customs.
I have a few connections but most dont come to adelaide only east coast then you have to ship from brissy to adelaide, the one above goes the whole way from west coast of USA to Adelaide
Quick question ... need to replace my dump pipe off the turbo on my Neo RB25. Would a 2.5" split dump pipe strangle any power, or should I go 3" split dump pipe?
I currently run a 3" bellmouth, but looking for a change.
:thumbsup:
:thumbsup:
Split dump, go see Andrew, he will sort you out!
Also still have the Senna DVD here for you
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
