Much cheaper than the kit they copied though. Much like their Geomaster knuckles... Speaking of which, if they retained standard ackerman angle, I'd be all over that shit. 50mm drop spindles FTMFW.
  • Replies 3.6k
Posted Images
I've just got rid of HICAS because the rear was out of control.... Was just doing whatever it felt like
Yea thats what i was going to suggest, bout to do the same on mine actually, rear is a little unpredictable at times.
just jap have a lock bar for i think $100, and looking at the DIY it doesnt look extremely hard to do.
Did you just chuck on a lock bar?
Driftworks have a nice kit that replaces the ball joints etc and all, bit costy though :/
yeah just a lock bar, it wasnt that hard to do, but you need a wheel alignment after, had some pretty epic toe in lol. I just adjusted it visually for the drive to the alignment place.
those that may not have Nene in their facebook here is one of her status updates a very grim warning
Janene Fulcher
At Elizabeth Centre when putting your children on the little rides. If an Old Lady comes up 2 u & starts poking her tongue out Sexually at your children Report her straight away. When my mum & I said we dont do that she kept going & i mean sexually poking her tongue out she then tried to get closer and closer to sienna & we are not exactly sure but it looked like she was going to pick her up.This happened to a friend of mine today! it is being treated as an attempted abduction by police. Janene
stage 2....pfffftttt
more car less camera Dave
Should be sufficient for the power I'm chasing. Don't need new springs and such with these either.
Hahahah, yeah... Now that I realise that money could've covered new wheel bearings, I do slightly regret it.
Slightly.
lol,
fitting up mine in a fortnight and cant decide to tune on flex or not. pros: it would be awesome and most likely make 310-320 ish. cons: that power would be useless, and if towing plans fall through for winton id have to take 400L with me. lol
yerp that my was daughter that Nene's talking about...Luckily the wife and mother in law were onto it!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
