  • Replies 3.6k
Posted Images
My dad and brother were at Argana Park last night as it was happening, and both said it was a 180? weird.
The story would have been made significantly better if the driver of the stolen car needed his legs amputated to get him out. And I mean that 100%.
f**k that we would be stuck paying disability allowances for him then
no doubt our indigenous friends were involved AGAIN! :worship:
And this is not a racist remark if it's backed up by fact....recent stats have been released that claim Aborigines make up 2% of our population yet are responsible for 20% of our crimes!! :domokun:
I.E. they commit 10 times more crimes than the white fella.
They also seem to have the Skyline as their choice of pleasure........can't wait to see what's gonna happen with Ins premiums in the next year or so.
You'll be able to pick up a Turbo Skyline for $4 or $5K with insurance to match the purchase price, LOL >_<
yeah not wrong there Pete. Its insane. Everyone with imports just make sure that your car isn't a easy target and that should deter these crims away from trying to steal a import :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
