  • Replies 3.6k
Posted Images
Enkei's arnt fakes. They are not trying to be something there not an are high quality,
Cheap wheels are fine so long as they are not trying to be something they are not. replicas are what ticks me off.
Does this go for everything or just wheels? Say the likes of kit cars? Not the real thing but a replica, and in some instances better than the real thing ( so im told )
Te37's, unlike shelby cobras are readily available, so no not really, its a different situation
Cheap wheels are sometimes fine for posing around on the street, however if you race on them, be prepared to possibly die or stuff it in the wall.
Having said that the number of fakes I see on the dyno that are basically buckled square from hitting tiny ruts in the road daily driving etc is frightening. There are no standards in this game of knock-off wheels, just the temptation to make them as cheap as possible to maximise margins. Thats the price some will pay for vanity.
That's why I use Rays Martin as you know, on the track safety is paramount, I value my life an wouldn't want a major wheel failure at 200km/h
Either needs to hold 240 ish need one cheap utill I can buy somethin decent as I got a drift prac cuming up with low cash so will take what I can get
what engine have you got R34 in a 34 or a neo engine gearbox in something else
poor man pays twice, why not get a reasonable clutch right from now and sort the rest of your shit out after
i can get a good clutch at a decent price just all depends on what you call cheap to quotes you may have received from other places
hey mate neo engine and box in my r32 drift car.mainly after something cheap as i wont have cash to buy something decent before my private day was going to wait till it dies so i can atleast attend and do a skid or 2. im not going to spend anymore then $1000 on clutch. If ure able to get me some prices on and array of a couple clutches would be awesome and highly appreciated
the number of TE37's that ive seen cracked lately from driving around on our shitty roads is also quite high!
mate just get what i have in mine. NPC 10 inch clutch. it is bullet proof and so driveable. wont cost you anywhere near 1K either.
+1 I can also vouch for npc clutches, got mine from madaz and simon installed it, i went the 9.5 which is about 100 bucks cheaper than the 10 and its really not that bad at all, no probs in traffic and can handle punishment, so overall great bang for buck clutch, get a quote from madaz
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
