  • Replies 3.6k
Posted Images
31 days since I got off the medication; I feel pretty awesome :)
Havent had one negative thought enter my head since getting off the Fentanyl.
Really looking forward to Medical Radiation Science studies at UniSA next year, 4years of hard work ahead but Im quietly confident Ive got what it takes ;)
Congratulations man - it really sounds like you're heading in the right direction.
Lols...
AK47, AR15, HK P90, Uzi, Barret M82A2, Walther PPK, Beretta M92F, Soviet RPG, Spud Gun, ? Car, Flintlock pistol, Lever action remington...
Sad. I know those all from memory but not the car
-D
Wow @ brake setup.
Jenna thanks very much, I feel awesome (mentally, knees a lil'bit sore but using a cream called ExitPain which I'm finding particularly helpful). I hope your back isn't giving you too much grief. If so try the cream I mentioned; available from chemists or health food stores.
Studying daily as I'm trying to take in as much as possible prior to uni next year. Its all coming along, first time in a long time I've felt like I've got something great ahead of me.... & Its mine for the taking. =D
anyone know the vacume hose setup for standard boost solenoid on a r34 neo is?
From looking around for a while i think it goes something like this:
Intake (air intake pipe) to a T piece, one end to the bottom of the solenoid and the other to the turbo valve?
Intercooler pipe to the top of the solenoid?
Anyone confirm this is correct?
Also i have an after market turbo (hypergear atr43 550hp) will take out the manual boost controller and using the stock solenoid (for defect sake) be ok?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
