  • Replies 3.6k
Posted Images
Lols...
AK47, AR15, HK P90, Uzi, Barret M82A2, Walther PPK, Beretta M92F, Soviet RPG, Spud Gun, ? Car, Flintlock pistol, Lever action remington...
Sad. I know those all from memory but not the car
-D
shame on u about the car :whistling:
hey big shout out to the lad in the r33 satin black at gazzanats did very well me thinkls looked real nice tbh
and dunno how u guys feel about s15's but the grey one doing the drifting was phucin schmick and drifted like a pro very nice :worship:
So, the current power figures are in on my engine build...about 220rwkw at 8psi, should know more tomorrow after the tune has been touched up a bit more, and it should be in my possession :D
A lot more torque and response has been gained, we compared the dyno graphs from its 260rwkw tune from October 2009 to tonight's...almost identical except for peak power and boost coming on earlier now. If we run anything higher then 8psi (actuator pressure) the clutch starts slipping there is that much power being produced, dyno sheets to come tomorrow hopefully :D
just to spice up todays wasteland. pick one or many, lol , work warning, skimpy clothes
http://pasnation.pasmag.com/_262380143714126443917102298617001702162338njpg/photo/15255155/94594.html
Edited by Carbon 34
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
