  • Replies 3.6k
Posted Images
hellloo
The rubber on the outside around my rear windscreen is pretty brittle and messed up, looks pretty horrible. I wanna replace it. My understanding that the actual seal that makes it water tight is underneath? anyways, no matter how much water I throw at it none comes through so thats fine. I just wanna make the outside rubber seal look a bit nicer lol.
Anyone know where I can buy a replacement seal? Any idea if its hard to put on yourself?
Thanks in advance guys
I had mine replaced by Spikes Auto (0417 003 663) when he did some panel work for me. He should be able to organise to have it done without panel work. You wouldn't want to attempt it yourself, the best way is to remove the window and fit an aftermarket seal as the genuine seals are several hundred dollars, versus less than $50 for an aftermarket one for a R32.
I'm not going to quote on behalf of anyone, but it was one of the cheaper things I've done on that car lol.
anytime is a good time Ryan. Sign up now so that you can attend the Club dinner on the 7th :D That way you get to meet most of the lads.
I shall warn you about Pete :P he is a meanie.........at times
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
