  • Replies 3.6k
Posted Images
Accommodation being booked tonight, in Munich for Oktoberfest :cheers:
Need to start drinking beer again (pitty i have been working so hard to get rid of this beer belly) so look out schutzenfest!
which is in 1 months today, almost time to start arranging the yearly SAU "responsible drinking" day - due to legal requirements around my liquor license i must 'preach' responsible drinking blah blah blah
Fwiw been doing some fuel consumption 'testing' before the e85 swap. over the last two weeks to and from work (stop start) the results have almost been identical. this weeks results with filling up today were i used 43L of petrol and did 397 Ks. A total of 10.8L per 100kms
Didnt think this was too bad considering the motors not quite stock. By comparison off the governments site a current SS Commodore uses 17.3L per 100, 370Z uses 15.2, Renault Megane Sport 250 uses 11.8
Interesting stuff
http://www.greenvehicleguide.gov.au/GVGPublicUI/home.aspx
Is that with or without an aftermarket ECU right now? Cos that sure seems pretty economical to me. I'm currently getting like 15.5L/100km (320km or so on 50L) on an untuned R34 with 3" exhaust, 10psi - just regular driving around town (It'll get 600km+ on 50L on the highway though). Planning to get it down to get retuned early next year for economy if nothing else. If I could possibly achieve that sort of economy around town I'd be stoked.
Yup, I understand why my fuel economy is poor - stock ECU - and it'll compensate with extra fuel. Which is why I ask if Jap_Star has a stock ECU. I'm guessing not, which gives me hope that I might achieve good fuel economy with a tune :D
If you can't get a Nistune for your ECU Jenna (some R34s you can, some you can't depending on what type/brand ECU is in it), then go an SAFCII. Had one fitted to my R34 with good results, and now have it on my V35. On the 35 the tune made an extra 8rwkw and flattened torque and all curves rather nicely. Obviously having a turbo and running rich you would see much bigger gains.
Yup, I already have a nistune fitted, unfortunately it's just still on the factory maps - I haven't had the $$$ to get it tuned yet.
Plan is to take it to Boostworx or Willall in the new year. Given the 182rwkw I hit on 7psi, with the 10psi actuator now in - I'm hoping with a retune power should jump to low 200rwkw, with better economy. That's the aim/hope anyway. :)
My '34 is finally getting where I want it - few major things left on my list are fitting the nismo 480cc injectors, fitting the HEL oil cooler w/thermostat (sitting in garage), and highflow the turbo (probably MTQ).
Thanks for throwing ideas and help out guys :)
mine went to hell once I fitted the new xforce cat. that little restriction from compliance cat to a full 3" or more from front to back , sent the fuel mapping wonky even after resetting the ECU,need to get my nistune ECU slapped in and tuned. and my actuator installed,
on a side note who down south can work on skylines and you trust , besides nissan and hp in a box, or grand nissan wreckers ? need my new clutch fitted and look at what kind of crap the other mechanic did wrong when they did the timing belt. before it eats it. belt is a gates kevlar racing belt.
does anyone have a Gates/HKS. or non factory belt on factory timing gears ? mine is making a shocking noise like its rubbing randomly , the car does have carbon fiber cover if anyone has issues with the cas not sitting flat because of the cover. the damn drive belts started sqealing this morning too, bunch of farking trained monekys cant even do the belts and hoses without drama
who can be recommended for nistune, dyno tune on the GTT down south preffered? I was told garage 7 ?
Edited by Carbon 34
Jenna my mate spoke with boostworx the other day and Shaun has a 5k old turbo sitting there he only want $1200 for it you should hit him up
Really wanna stick with an R34/OP6 high-flow if I can - my power goals are only 240-250rwkw. More chance to get through Regency without me needing to change back to a factory turbo .. Do you know what sort of turbo Shaun has?
That's about what I get in my dead stock R33 GTS-T. In regular commuting traffic my fuel economy hovers around 10.5 to 11 ltr/100km, on whatever the pump 98 RON is I get. And that's with a mighty 128rwkW ;D
WILLAL
its a no brainer really, plus club discount
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
