I have decided to go with a dry sump system on a build i am doing and i am a newbie with respects to the dry sump system.
What should be considered when purchasing the oil pump ?
3-4-5 STAGE PUMP?
STANDARD OR REVERSE ROTATION MOUNT SELECTION?
RPM speeds
Gallons per minute
etc
https://www.sau.com.au/forums/topic/365507-dry-sump-system/
3-4-5 STAGE PUMP?
RPM speeds
Gallons per minute
etc
Atleast two of these are simple enough, the standard or reverse mount implies how you will mount the thing on the block. Meaning do you need a pump that pumps when spinning clockwise or anticlockwise? Reference that with your motor and how you plan to mount it.
RPM speeds are also simple enough, its all application specific.. how are you going to drive it, how many rpm will your motor do, what sort of drive ratio will be on your belts etc. Think of it like under driving a water pump to stop it airating at high rpm :thumbsup:
As for flow and however many stages, you will need to speak to people who have built these sort of setups before. Vivia la 10k oil setup!
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5831648
From what I've learnt lately (I'm building a dry sump setup now) -
  • The pump is normally run at half crank speed. This is because normally can only turn up to 5000-6000 rpm.
  • The gears in a usual pump are much larger than the stock pump, so flow is not really much of an issue. You will normally get excess flow (which causes increased pressure) and the pressure regulator in the pump will bleed it back into the scavenge stages.
  • Stages depends on what you are trying to achieve. More stages means more even oil collection accross the entire engine and more vaccum, it also means more complexity. You can run a two stage pump if you want but you may not achieve the vaccuum or oil pickup evenness you want (because you can't scavenge the head)
  • It doesn't matter which side of the engine the pump is mounted.... it will turn the same direction regardless (clockwise)
So yeh, it depends a lot on your wallet and what you're trying to do.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5831741
What if it were backward mounted it on a transverse fwd motor?
There's a reason they offer it standard or reverse which is application specific. Where its mounted on the motor is a reasonable example to which the OP will need to get his head around to understand what hes doing for this project and future.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5831785
I'm pretty sure the reverse rotation is for the hondah motors that run anti-clockwise.
Anyway....lots of ways to f**k up a dry sump system. I think you should get someone who understands them (ie demonstrated experience) to set it up. Anything wrong and you kill the motor just as quick as with a wet sump
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5832764
there really is not much to it.. anything over a 4 stage is overkill. + hard to mount. they get pretty long.
also the pump style is important aswell.
a simple aviad spur gear pump is basic, not pull much vacume but will take alot of crap.
or a uber expencive auto-verdi roots style pump is better but higher maintenance and pull heaps of vacume.
anything over 12-15 inches of vac will ware out little ends
my fave is dailey engineering ones. robust and roots style scavenge.
you also want one with a built in scavenge manifold for easier plumbing.
bare in mind the price of hose and fittings. eg -12's and -16's range from $50-$100 per fitting for anything other than a straight.
hose -12 $40-150 a meter and -16 $50-230 a meter
our race car at work used 9 meters of -16 2m or -12 and 5m of -10. 10 -16 fittings 4 -10's and 7 -12's...... or and 3 -16 45 degree bulkheads and a -10 bulkhead.
the pump is a SMALL PERCENTAGE of the cost.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5832919
As much as I want to support local business, these fittings are available at less than half the price on eBay. Considering the local stuff is likely to be made in China/Taiwan anyway the quality is exactly the same. The -12 fittings and hose for my 4 stage come to around $300, I have to get a 2 meter -16 made locally which is going to break my wallet.
Overall my dry sump will probably end up costing around $1500 inc. pump, tank, fittings and hose. The sump I'm fabricating myself. It's not bad when you consider a Nitto pump + collar is around $1500 and you still need a high capacity sump to be completely safe.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5834287
Earls are quality and they also offer fragola as a budget option.
Using cheap fittings is asking for trouble. Same goes for hose. It will end in tears.
Make up a hose and have pirtek pressure test it. I have a pressure tester and adaptors if you are local and want to compare a cheap hose and hose end to a quality one......
If you can't afford to do it properly then seriously you
shouldn't be doing it at all.
I'm all for saving a dollar but good luck with leaky cheap fittings.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5835027
There is only one line under pressure, the rest are in vaccuum. The one pressure line only needs to take 150 psi max which isn't really that high for 750psi rated -12 hose.
I'm taking plenty of pics during my build so I should be able to write it all up in a few weeks. If the engine runs for a week and dies then I'm willing to learn from my mistakes and rebuild.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5835966
Matt if mine only lasts for a week I'd be in a deep depression, I'm also using cheep hose and fittings so I hold it holds together and a $1500 dry sump setup is bloody good value as u said my nitto and sump extension has well surpased that price
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5835988
Dry sump is a waste of time unless its a track only car.
I still cant see the point of having massively excess flow rates if the motor only really requires say 50% more flow than is need to get to the pressure releif valve set point. All you will do is loose power through parasitic loses of the pump(and slightly negative sump pressure isn't going to make for the parasitic losses of the pump).
But if you do decide to waste money then make sure you scavenge the head.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5836005
If you have vacuum in the crank case why would you need to.
Post in here: http://www.skylinesaustralia.com/forums/topic/365583-dry-sumps-and-you/
Can we get threads merged?
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5836131
You need a motorbike to go with the car. If at least one of them is one the road then I'm a happy man :thumbsup:
Well I had 3 options -
Stock/N1 oil pump
Nitto oil pump + extended sump
Dry Sump
The stock and N1 pump sucks. It's pot luck whether they live 10+ years or crack within 2 weeks, I didn't want to risk forged rods and pistons on a $400 oil pump.
The dry sump has every advantage over the Nitto + extended sump. It costs less, it's a more stable oil supply, I can rev higher and I get to learn about designing and fabricating a dry sump. Seemed like an easy decision for me. I don't see how it could be a waste of time, once it's setup it's done. Just stick to regular belt and oil changes it should look after itself and the motor.
In a decent 4 stage setup the sump pressure is a fair bit lower than slightly negative. It's enough to eliminate the head -> sump oil flow issues and the majority of the vapour trail behind the crank. General opinion (from what I've read) is that dry sumped cars rev easier and have better fuel economy due to the lower windage losses. I haven't experienced this first hand as this is my first dry sumped car but I'm looking forward to finding out how the engine feels.
https://www.sau.com.au/forums/topic/365507-dry-sump-system/#findComment-5836138
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
