hi iam just about to pull the donk out of the 32 i know it can be dropped out the bottom as a whole 'and pulled out through the engine bay . from peoples expeirence witch way would be the easyer of the two i only have a trolly jack and an engine crane and the gear box has to come out aswel :cheers: cheers
https://www.sau.com.au/forums/topic/365631-r32-gtr-engine-removal/
Unless you have a hoist, take it out the top after you remove the gearbox. With one jack and a couple of stands, you would never get the car body high enough to get the engine out from under it
when taking the engine out the top can i take it out with the box attatched ? what would the problem be doing it with the box on ?
Can be done with the box attached, just have to stuff around a bit to get the angles right to clear the tunnel and radiator support.
I'd highly recommend doing a google search to find the R32 service repair manual. It shows you step by step how to remove and re-install the motor aswell as other general service procedures.
Cheers,
Johno
i have a hoist in my garage... would it be best for me to drop it all out the bottom when the time comes for me to pull my motor? i was planing on taking it out the top, but if its easyer which im guessing it would be as there would be less to deal with when it comes to the Gearbox. dose all the suspension in the front end come out with it?
I once lifted the whole front of a GTR I had with the engine crane and slid the motor/subframe/gearbox assembly under it on the jack and bolted it up lol.
Its do-able either way but you prob wanna take it out the top way if you dont need to remove the box.
I pulled mine out through the top. Manifolds and turbos can stay on. Took me about half/to and hour to take it out, but i already had the box out. I had trouble with the RHF drive shaft and couldnt get it to pop out of the diff. Ended up cutting the inner CV boot clamps on that side, popping out the circlip and removing the shaft from the CV housing.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
